New Stereo for 05 Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by sassy01ss, Sep 23, 2019.
  1. sassy01ss
    sassy01ss New Member
    I want to install a new radio in my car so i have bluetooth, eta like all the newer cars. It's just a commuter can but i miss having all the fancy stuff. what is the best way of going about this. is it worth it to upgrade? think best buy knows how to install properly? What radio do you all suggest?
  2. Grundignz
    Grundignz Junior Member
    25
    Wellington, New Zealand
    I have base model prius too.MFD 86110-47080
    I was thinking of trying to upgrade to later MFD screen with the built in Bluetooth.
    86110-47210 or 86110-47230
    Not sure if this will work but can only try!!
    Havent managed to find much information out there does anyone have breakdown of the MFD part numbers and what differences they have.
    This is what i have complied so far:
    Model Buttons Resolution Bluetooth GPS/Nav Camera JBL
    86110-47080 4 Low N N N N
    86110-47081 4 Low N N N N
    86110-47230 4 Hi ? 6 SPEAKER SYTEMS ONLY FOR 06-09
    86110-47210 4 Hi Y Y Y ?
    86110-47070 7 Low? ? ? ? ?
    86110-47071 7 Low? ? ? ? ?
    86110-47220 7 Hi Y Y Y Y
    86110-47060 4 Japanese
    86110-47061 4 Japanese
    86110-47062 4 Japanese
    86110-47050 7 Japanese
    86110-47051 7 Japanese
    86110-47052 7 Japanese
  3. Grundignz
    25
    Oops lost formatting
    try this attachment
  4. dolj
    dolj Senior Member
    8,553
    4,344
    Try this:
    1 86110-47080 4 Low N N N N
    2 86110-47081 4 Low N N N N
    3 86110-47230 4 ? 6 SPEAKER SYTEMS ONLY FOR 06-09
    4 86110-47210 4 Hi Y Y Y ?
    5 86110-47070 7 Low? ? ? ? ?
    6 86110-47071 7 Low? ? ? ? ?
    7 86110-47220 7 Hi Y Y Y Y
    8 86110-47060 4 Japanese
    9 86110-47061 4 Japanese
    10 86110-47062 4 Japanese
    11 86110-47050 7 Japanese
    12 86110-47051 7 Japanese
    13 86110-47052 7 Japanese
    Search these Gen 2 forums for some posts where a member posted the mapping of the pins between 4 button and 7 button units.
    I would steer away from Japanese MFDs.
    Also, to get bluetooth you might consider leaving the MFD as is and replacing the radio unit with a newer double DIN unit with bluetooth and android auto and/or Apple CarPlay.
    #4 dolj, Sep 28, 2019
  5. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    I recommend aftermarket stereos. We are getting great results from a Sony xav-ax100.
    I would not recommend Best Buy for installation. Seen too many problems.
    Nearly every town has a smalltime stereo/security dealer who is a lot more dependent on getting it right than BB.
    JC91006 likes this.
  6. Grundignz
    25
    The only reason for the japanese listed units is because here in New Zealand we have more JDM imports than NZ new models so its probably 1 in 10 that actually have display in english!!
    Opps my bad just noticed your in Wellington too
    #6 Grundignz, Sep 29, 2019
  7. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Just be aware that the BT radios from the factory for G2 Prius have BT for phone only, no audio streaming. You can get an aftermarket radio for your G2 that's light years ahead of any factory G2 radio for under $100.
  8. Grundignz
    25
    Just good to be able to make use of built in unit. and for my other one convert display to English from Japanese
