New stereo sounds awful
Discussion in 'Gen 2 Prius Audio and Electronics' started by GrumpyWolf, Jun 16, 2024 at 1:30 AM.
  1. GrumpyWolf
    GrumpyWolf New Member
    Sunday
    united states
    Just had my 2008 prius with the JBL system upgraded to a aftermarket stereo. Ever since the new stereo was put in the audio is just unbearable, it's super quiet and if I turn it up past half way the speakers distort horribly. I have used this same stereo in my 2006 eclipse with a stock rockford fosgate setup and it sounded fine. I've tried tweaking all the settings in the stereo, nothing helps. Is is just something to do with the AMP that the car comes with? I had a shop install it and I know they used a harness to get everything connected properly. Only thing I can think of is they somehow just bypassed the amp and it's literally just playing right from the head unit now. It literally sounds worse now than it when it had the factory stereo in it. Once thing I did notice is the stereo has a internal amp button in the settings, and if I turn it off I get no sound, which is what makes me believe they just bypassed the amp.
  2. dolj
    dolj Senior Member
    7,602
    3,832
    Wellington, New Zealand
    The installer should have adjusted the stock JBL amp to approximately 50% volume before disconnecting the stock H/U. It sounds like they did not do this. If the JBL amplifier volume setting is too low, you get terrible distortion when you turn the volume up on the new H/U.
  3. GrumpyWolf
    Sunday
    united states
    Thanks, I went back and checked, they didn't bypass the amp. So it sounds like they didn't adjust the amp. Gonna be honest, I've had horrible experience with shops and don't trust them to do anything right. Does the amp simply have a knob or something to adjust? I do know how to access the amp but I didn't see any adjustments.
  4. Leadfoot J. McCoalroller
    7,104
    6,658
    Pennsylvania
    2018 Prius c
    Your old stereo was the control. It will need to be reconnected (at least temporarily) to adjust that gain setting, and then disconnected again.
    Autosound shops have been in a death spiral. People don't spend much on aftermarket systems anymore, so the field doesn't attract much talent, so customers get bad results, so there's less spending on aftermarket systems...
  5. GrumpyWolf
    Sunday
    united states
    It actually turned out to be the amp, audio died completely, took it back and they tested it and the stereo is putting out sound, but the amp is dead. Ended up just getting a replacement OEM on eBay for 65.
  6. Leadfoot J. McCoalroller
    7,104
    6,658
    Pennsylvania
    2018 Prius c
