New Struts or New Mounts?
Discussion in 'Gen 2 Prius Main Forum' started by skittle021, Jun 5, 2021.
  1. skittle021
    skittle021 New Member
    16
    Mississippi
    I've got an 05 Prius that the strut mounts seem to have completely disintegrated on. I haven't done too much suspension work in the past, so could anyone tell me if these mounts are replaceable, or if I should just replace the entire strut? There is no leakage on either of the struts and they were working great until last week. If the mount is replaceable, does anyone know a part number or have any links that could direct me to to get these replaced? I'll attach a couple photos to this post.
    #1 skittle021, Jun 5, 2021
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    We’re working great till last week lol....looks like both shocks have busted off
    Long time ago. Never seen anything this bad before.
    how many miles on this car?
    take some more pictures under the car in the front and in the back let’s see how bad the front and rear suspension is under there the struts may be the least of your problems.
  3. PriusCamper
    PriusCamper Senior Member
    11,115
    4,523
    Pacific Northwest, USA
    Fairly certain the damaged parts in your photo is part of the strut itself not part of the car's actual mount.
    And these days you can get a really low price online for struts that are already mounted to new springs so it's an easy nuts and bolts swap for DIY folks, though you do need to get an alignment job afterwords to do it right.
  4. Samuel Williams Jr
    246
    Dayton NV
    Oh I see it now. The orange part is the "Bump Stop," And I have never seen a Bump Stop disintegrate like that? So add that part into your to be bought pile. And yes the strut mount and the bump stops are available. But if it has the original struts you should replace those also. The whole strut assembly has to come out and be disabled to replace the strut mount or the bump stop. It makes no sense to replace just those parts. And E bay, Amazon or RockAuto all have the parts. But something is going on here? Are the parts all original? What do the tires look like?
    And here is an overview of what you'd knew to do.
    And you'd need a coil spring compressor to take the strut assembly apart and put it back together. And you can rent those from most auto part stores.
  5. PriusCamper
    11,115
    4,523
    So much less hassle to just buy springs, struts and mounts all pre-assembled and ready to install, especially considering how badly damaged these are. Those cheap spring compressors can kill people!
  6. skittle021
    16
    Mississippi
    Thanks guys. Believe it or not, the struts seriously were not like this a week ago. I checked them and everything. I bought this car from a Copart auction and it sat in the Texas desert for a full year before I bought it. It seems the heat damage has affected almost every surface of this car. Rotten tires, dry rotten plastics, bad suspension bushings, etc. The car looks nearly mint underneath though. No rust or anything and no damage whatsoever aside from a couple nicks and chips on the underbody cover. No leaks or anything either.
    I took it on 2 90-mile road trips just about a week ago, so I guess the strut mounts and bump stops gave up the ghost somewhere on the trip. I don't have any idea whether or not these are the stock struts or not, so it may be best to just replace all of it and move on. I just hate to put even more money into after spending about $4,000 to bring this thing back to life. I only paid $500 for the car, though.
  7. Samuel Williams Jr
    246
    Dayton NV
    You don't "need," a multi thousand dollar coil spring compressor to compress a coil spring? Shop's use them because, time is money not because a hand coil spring compressor is "Dangerous?"
    But he was asking about individual components not the whole strut assembly? If he wants to replace the whole deal as an assembly? Easier still, you don't need a spring compressor at all. You just leave the car on the ground, undo the strut mount bolts break them loose. Leave the top nut alone and the whole assembly drops out as a unit.
    To disassemble, as a unit, with the weight on the car hit, the strut nut with an impact gun to undo it. The weight of the car keep's the spring compressed. The weight of the car keep's the spring compressed, then jack the car up and the pieces come apart not under tension.
    You only need to compress the spring, if your taking the Strut Assembly apart, otherwise you can safely remove it as a unit. But I don't what, the OP plans to do or replace?
    PriusCamper likes this.
  8. PriusCamper
    11,115
    4,523
    yes... Ever since I started watching tik-tok there's an amazing amount of repairs you can get done by creatively using the weight of the vehicle rather than powerful expensive tools only a high volume shop can afford.
    Samuel Williams Jr likes this.
  9. Samuel Williams Jr
    246
    Dayton NV
    Do you have a link to the tik-tok thing, I'm not sure how that works?
    The leaving the car on the ground bit and using an impact gun, is not me. That came from my friend way back in the mid 80's? It sounded nut's to me at the time but what the hell? I'll try and see what happens? It worked out fine. :)
    The cheap coil spring compressor back in the day. Did not have "retaining clamp's," to secure the coil spring? What that meant (first hand experience) is that as you tightened down the spring compression the clamp could slip, and as you loosen the top nut, it could shoot that top nut off like a hand grenade! A truly butt pucker experience. 1981 Chevy Citation I was changing over to Koni Shocks.Good time's good time. :)
    And yep you are correct ,if you just swap the complete shock, spring, top mount assembly out ... you don't need a spring compressor. You just take the top nut off with the car on the ground and no one need's to die. And put the new assembly in place and thread down the top mount and lower the car to seat the strut.
    But I did miss that because I don't do stock. I usually change to Camber Plates and shorter spring's so no need for a Spring Compressor to reassemble. :)
    But my wife is not really a fan of my work? Dropping our Gen 2 will not really set to well with her? But hey it does have a leaking rear shock! So I got my opening! :)
  10. PriusCamper
    11,115
    4,523
    Ask a teenager to show you how to use tiktok
    As for your wife, how about you compromise and lower the car an inch on the front and lift it an inch on the rear?
  11. Samuel Williams Jr
    246
    Dayton NV
    Aww well these day's my life revolves around helping vet's (I am a PCA, personnel care assistant) training dog's (Boxers and Working Line German Shepherd and Pitty guy)
    and well car's. I don't know any teenagers?
    I have never raised a car a car in my life? I was gonna drop our fuel sucking, Denali but my wife wrecked it. :(
    But why would I drop the front and raise the back? I don't get it?
