New tire and bad mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by yoyoman, Feb 20, 2009.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I have 2005 package 6 Prius. I have replaced all 4 tires recently with Michelin Primacy. With the new tire, my MPG has dropped from 52 to 45. Is this common with the new tire? I have always maintain 42psi in all tires, oil level is at the middle level from Low to High, and air filer is new as well. Any idea?
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    All new tires will have an intial break-in period. That's normal.
    After a few thousand miles, they will wear down enough to lose that sticky quality from the tiny firm edges on all the tread surfaces. Then you'll find out what the rest of the life of the tire will yield for MPG.
    The first rotation will bring back a minor MPG down too. But that wear down takes less time to overcome.
  3. yoyoman
    342
    117
    San Jose California
    Thanks for the respond. Will premium gas help the mpg?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Nope, not recommended.
  5. lytthans
    lytthans Junior Member
    52
    I recently put Pirelli P3s on my Prius and the mileage actually improved 3-4 MPG. My average is now 44-45MPG.
  6. dipper
    dipper Senior Member
    1,242
    252
    They still selling P3? I thought P4 is the replacement. They have the 44 PSI max.
    I got a set of P4 for my wife's Prius. It gets maybe 1-2 mpg lost (new). But handling and crosswind issues I had are now gone.
  7. icarus
    icarus Senior Member
    4,884
    976
    earth
    FYI Premium gas will not only NOT increase your mileage,, but it will decrease it!
    There is actually fewer BTUs available in a gallon of higher Octane gasoline than a lower octane.
    Icarus
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Also note tire diameter when replacing tires. Different tires, even of the same size, will have differing circumferences, which introduces error in mileage measurements. You may think you are getting better mileage, or worse mileage, but it may be an illusion.
    Tom
  9. violinguy
    violinguy Junior Member
    29
    Virginia
    I put Pirelli p4 four season plus tires on my wife's 05 and her mileage dropped from 45 to 38 mpg. Had Bridgestone Ecopia on there. Not impressed with the Pirelli.
  10. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I just have put on new Bridgestone Ecopia 185/65R15 tires on my '04 Prius. Original equipment size. I had 195/60R15 's on it before.
    Mileage slightly better. The noise level is unbelievably LOW! The ride is smooth even with 44 PSI in front.
    I Love 'im
  11. Mendel Leisk
    41,528
    EP422 Plus I assume?
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I've been really happy with my old Ecopia EP100s. I'm on my second set now and although their longevity is nothing spectacular (though still quite ok at about 75000km / 45000 miles), their proven low rolling resistance performance makes them a winner for me. I've been consistently getting tank averages in the 52 to 58 mpg range for the past 3 or 4 years with these guys. :)
