New Tires- Big Mileage Drop
Discussion in 'Prime Fuel Economy & EV Range' started by BirbLuver, May 12, 2024.
  1. BirbLuver
    BirbLuver New Member
    New England
    I replaced the OEM Ecopia EP422 tires on my 2017 prime back in December. I choose Continental True Contact Tour which are marketed as low rolling resistance ["EcoPlus Technology"].
    I saw an immediate and dramatic drop in mileage on my daily commute (100 miles roundtrip on the highway, same route every day). Initially the drop was about 20%. After 5 months/7000 miles, I am seeing something closer to 15% higher gas consumption than the OEM tires for the same weather conditions.
    I thought that part of the issue was change in tire diameter (revs per mile) but I checked the odometer reading for my commute and it is actually reading higher (higher revs per mile) with the new tires. Odd given that the old tires were practically bald. Based on this, the mileage loss probably a bit worse (by a few percent) than I thought initially.
    Has anyone else seen such a dramatic drop in mileage with new tires ? Anyone have experience changing out the OEM tires for Continental True Contact Tour ? If so did you see a big drop in MPG ?
    Anyone know of a source for accurate rolling resistance test data on new tires ? I thought I was buying low rolling resistance tires but apparently you can market anything as LRR regardless of the actual performance. Would like to avoid this problem in the future but how ?
    51,155
    percentages can be misleading, what were your former mpg's and what are they now?
    what tyres pressure are you running?
    who installed them, could any of the brakes be dragging?
  3. BirbLuver
    New England
    My MPG varies quite a bit with temperature. The initial 20% drop (back in December) was from ~62MPG to ~50MPG. Right now (mid May) I am seeing about 56 MPG. I would have expected about 66 MPG this time of year with the old tires.
    I run about 2psi over the factory recommended pressure.
    The work was done at Walmart and they did use the wrong wheel nut torque (off by a different amount on every nut) and underinflated one tire. I did not see any obvious problems beyond this.
    My initial thought was that there must be a problem with the brakes. In an attempt to rule this out I did all new rotors & pads and cleaned/greased everything. I don't think the brakes are dragging, although I guess there could be something weird going on that was not obvious with the car jacked up and the wheel off.
  4. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    FWIW, short answer tire pressure - increase by 4 pounds and report back.
    The long answer is the rolling resistance rating difference of the OEM (or former) tire vs. the Conts.
    Even if both say 400, the rating is as compared to same-brand tires, not between competitor brands.
    Ditto, the tire pressure door sticker is for OEM tires and may be different settings for aftermarket/ other brands.
    A pyrometer is a great tool to own (as is an accurate tire pressure gauge).
    Lastly, brake drag is a valid comment as mentioned above.
    Lubing the brake pad pins is good maintenance plus a failing/ old 12volt battery is also known to reduce mileage.
    Both items have been discussed on our forum before.
    Good luck.
  5. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    New tire tread is typically less stable (squirrly) than worn tires due to the tread depth. It does take some time for them to "scrubb-in"
    When I changed my tires I saw a 2-3 mpg drop even after 2-3 PSI increase from normal (33 to 36 psi).
    After 5,000 miles I did get 1-2 mpg back.
    I also noticed you changed out in December. Did it get colder temps after the tire change?
    Cold weather really eats mpgs. Typically I get 35 in winter and 45 in the summer heat. (40 mpg avg.).
  6. Danno5060
    Danno5060 Active Member
    358
    182
    Wyoming
    It's probably too late, but were there any signs of unusual wear on the old tires?
    Jack up the front end and try to wiggle the wheels side to side to check the tie rod wear and bearings. Wiggle up and down to check the ball joints and bearings.
    Maybe try the same on the rears to see if there are any bearing problems there too.
    Maybe check the alignment?
  7. Mendel Leisk
    40,586
    Replacing the the stock Michelin Pilot HX MXM4 (in 215/45R17, on our 2010), with Michelin Primacy MXM4, our mpg dropped, near 10% IIRC. That was a few years back, and it’s only partially recovered to date. Is what it is.
  8. BirbLuver
    New England
    Not sure if folks saw my response to Bisco. My response was held up for moderator review. Just in case, I have copied it below.
    kenny9494, I replaced the 12V battery (no improvement). "the rolling resistance rating difference" do tire manufacture's publish a rolling resistance rating ? This is news to me. I did not run into this when I was shopping for tires.
    danno5060, I have not see any evidence of alignment or suspension problems. The tires I replaced had 80,000 miles on them and tire wear was remarkably even.
    Mendel, what you describe seems similar to what I am seeing except I think I am seeing a slightly larger drop.
    bisco:
    The work was done at walmart and they did use the wrong wheel nut torque (off by a different amount on every nut) and underinflated one tire. I did not see any obvious problems beyond this.
    Danno5060 likes this.
  9. Mendel Leisk
    40,586
    See rear brake drag link in my signature (on a phone turn it landscape to see signatures). It’s Gen 3 but Gen 4 rear brakes may be similar. The rear brakes can be reassembled with misaligned brake caliper piston, and this imposes drag on wheel rotation. May or may not be a factor, but good to check.
  10. pasta4breakfast
    99
    46
    Anaheim, CA
    2020 Prius Prime
    How many miles did the OEM tires have on them when you replaced them? If these were the factory installed tires in 2017 and you are driving 7000 miles in five months, I would assume the old tires had a lot of miles on them. I would think really worn tires would get phenomenal fuel economy. when I switched from the OEM Dunlop East save tires with 43,000 miles on them to new Michelin X tour tires, I noticed a 10% drop in EV efficiency. It took over 20,000 miles on the x tour tires to notice any improvement. It took almost 40,000 miles to gain half of the loss back. I don’t know what the loss would have been if I had something like 70,000 miles on the OEM tires.
    Also, because the MPG includes the EV range, small changes in efficiency can wildly swing the number. For example, take a 90 mile commute with 30 miles EV range and 60 miles per gallon when driving in HV mode. If the drop in efficiency of new tires changes your EV range to 25 miles and your mpg in HV mode to 50 miles per gallon, your total MPG drops from 90 MPG down to 69 MPG. In this example a 16.7% drop in efficiency lead to 23.3% drop in the mpg displayed on the dash. I think the miles per kWh gives a less distorted picture. There is a display where it shows you the monthly miles/kwh. I recommend looking at that. I included a picture on my dash as a reference.
  11. BirbLuver
    New England
    Mendel, I read you posts regarding parking brake & rear brake drag before I did the rear pads/rotors. Pretty sure that I got it right when assembling.
    pasta4breakfast, I am not charging so the MPG is not affected by EV operation.
    I think I got unlucky with my choice of tires. Going to have to consider replacing them early. Wish there was some way to determine rolling resistance prior to purchase.
    pasta4breakfast and Mendel Leisk like this.
  12. Danno5060
    358
    182
    Wyoming
    I recently got new tires for one of my fleet of Prii. That was my exact same thought too.
    I change over to winter tires, and it was the summer tires I was buying. I looked for tires with "low rolling resistance" and kept coming up with all season tires, where they kept reviewing the winter weather handling. I'm not concerned with that because I switch to studs for the Wyoming winters.
    I finally gave up as there's no specific rolling resistance number. In the end, I figured that the mileage rating might somewhat serve as a rolling resistance proxy. A harder compound tire would probably last for more miles as well as have a lower rolling resistance. At least that's how my thinking went. I ended up with a set of Pirelli "high mileage" (80,000) tires from Sam's Club (no Costco here, and I went around to see what just about everybody in town had for tires).
    I can't tell you if the new tires are any better or worse for gas mileage. The car I put them on was my 2019 "new to me" Prime. I bought it in late December, and immediately swapped over to a set of Winter studs. Those definitely take a bite out of the gas mileage, but I don't want to worry about the winter icy roads. The whole fleet (Gen 2, Gen 3, and the Gen 4 Prime) use 195/65R15, so the tires don't have to go back on the car they came off of. At the end of the winter we decided to put the tires that came with the new car on the Gen 3 and get new summer tires for the car that drives the furthest distance.
    I read one review after I bought the Pirellis that said they were really noisy. My experience was not that at all. Maybe just a little more noise than the ones that came with the car. I figured were cheap and soft, something that a car dealer would put on a car to sell and not what I'd put on a car to drive. The Gen 3 Prime is still quieter and smoother than either of the previous Prii - especially when running in EV.
