New tires makes this Prius so much nicer
Discussion in 'Gen 3 Prius Main Forum' started by StevefromOhio, Jul 24, 2018.
  1. StevefromOhio
    StevefromOhio Member
    sarasota florida
    2018 Prius Prime
    Recently changed out the factory Goodyear tires for a set of Michelin Energy Savers. What a difference!
    The Prius was kind of noisy and not very comfortable as the Goodyears IMO are not a very good tire.
    The Michelin tires are a whole new ball game. Very quite. Very comfortable. Makes the Prius into a different car.
    Little tip......when getting new tires, make sure you give the installer a bottle of 303 protectant. This stuff is amazing. Have him before he mounts the tires on the rims, spray the inside of the tires. When you get home at night, spray the outside of the tires, including the tread. Let it sit for about 12 hours. You need to coat the outside of the tires every three months or so. Only need to do the inside of the tires once.
    I was made aware of this stuff from a friend who uses 303 on his tires and has tires that have had almost no tread wear and ride like the day they were new, with over 130,000 miles on those tires! The 303 protects the tires from dry rot and also makes them less prone to wear without affecting traction. Also works great on the rubber boots on CV joints which commonly fail and cause CV replacement due to dirt infiltration. Makes everything rubber or plastic last. Highly recommended.
    49,446
    welcome!
    i got the michelin energy savers last summer, love them!(y)
  3. prev93
    prev93 Member
    63
    Califon, NJ
    Energy Saver or Energy Saver A/S?
    Merkey likes this.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,016
    764
    Virginia, USA
    I gave my installer a bottle of Bacardi 151. I think your choice is better.
    ITBland and bisco like this.
  5. bisco
    49,446
    i disagree.;)
  6. StevefromOhio
    sarasota florida
    2018 Prius Prime
    Energy Saver. The A/S or all season has a more aggressive tread and so it is a bit louder.
