New Tires Mystery
Discussion in 'Prius v Fuel Economy' started by Krsna, Mar 8, 2023.
  1. Krsna
    Krsna New Member
    oakland
    After reading so many threads on tires and fuel economy and nothing really seeming scientific or conclusive, i decided against LRR and instead to get the tires in my budget that had the performance I was looking for. Since inflation, tires have seemed to have gone up 50% where I am in California, so even a set of budget tires cost me $560 total. Because I could not find adequate information and most tire threads are full of anecdotes, I just decided to roll the dice and go with Kinergy ST H735, tires that no one really recommended for the Prius.
    Before I was getting about 40.5 mpg at 40psi. 42mpg if I drove conservatively, but the way I normally drive it averaged 40.5. I got the new tires and waited about 1500 miles of break in to start clocking the mpg and tested the psi for a few hundred miles, all driven the same.
    At the standard 36 psi I was getting a slightly disappointing, but expected 38 mpg. Lots of people said to expect a drop off if you didn't get LRR's so I was actually ok with this drop.
    Here's the weird part: I decided to bump the psi to 40 and the mpg went DOWN to 36mpg. I have no idea why this happened. The ride comfort was terrible too.
    Then I tried 38psi and it went up back to 40.5mpg.
    Anyways this is just another anecdote, but I figured I'd give my experience with the Kinergy ST H735, which I'm now very happy that I got no drop-off in mpg.
    36psi = 38mpg
    38psi = 40.5 mpg
    40psi = 36 mpg ????
    Thoughts? I can't explain the significant drop with higher tire pressure.
  2. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Well, I'll speculate.
    1) The tire traction ratings may differ....even though brand-to-brand ratings are valid, changing brands brings a variable.
    If your original tires were rated 400, and the new tires at 200, well that could be. Typically, a lower rating causes decreased mileage.
    2) Alignment has changed over time and you are dragging your front toe. Typically, a cause of decreased mileage.
    3) Maybe it is tune-up time? Engine air filter. Typically, a cause of decreased mileage.
    4) Seasonal gasoline formula changes. Typically, a cause of decreased mileage.
    5) Tire pressure.
    Well bumping up the pressure usually increase miles per gallon, but increases wear on the center of the tire.
    So maybe, I am guessing, the higher pressure is increasing traction, noting # 1 above.
    Or the higher pressure is increasing the tire temperature over its performance operating range.
    Do note, with a tire brand change, a pyrometer is your friend.
    FWIW you can ballpark pressure by looking for a 10% rise in pressure from cold to hot.
    Looks like you found 38 psi as ideal.
    So anyway, all guess and no answer.
    My vote would be toward traction ratings and/or tire temps.
    Good hunting :)
    Krsna likes this.
