New tires YOKOHAMA AVID ASCEND . Loss about 1-2 mpg. Not upset.
Discussion in 'Gen 2 Prius Fuel Economy' started by bobodaclown, Jun 6, 2019.
  1. bobodaclown
    bobodaclown Member
    216
    72
    Hello All,
    Just replaced my tires all 4 from ECOPIA EP422 to YOKOHAMA AVID ASCEND and changed out front and rear shocks/struts. Nice change all the way around. Did the shocks/struts first. Used Monroe quick stuts in the front. Pretty easy job overall. Rode on the old tires for about 2 weeks or so. Just didn't have a chance to get the tires, and do the alignment. Handling was much improved. Didn't realize how worn the old suspension was.
    Was averaging (computed) about 44-45 mpg.
    Installed new tires, YOKOHAMA AVID ASCEND, wow, they are quiet compared to the old, worn EP422s. So far I'm satisfied, only about 500 miles on them. My daily commute is about 60 miles round trip, 20 local roads 35 mph, and 40 highway 70+mph.
    Tires are rated for 85K, I'm hoping to get 5 years or 75K out of them. Then the car will be 15 years old with over 200K, maybe time to replace. :)
    I'm in Southern California, south of Riverside, normally commute the 215. So haven't had bad weather to really workout the tires. But so far I'd recommend.
    Oh, the only unscheduled maintenance I've done is the inverter coolant pump (DIY $100), and brake accuator ($1800 ($1200 part/$600 labor) past extended warranty by 3 months). I've pretty happy.
  2. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    Did you get regular YOKOHAMA AVID ASCEND or newer YOKOHAMA AVID ASCEND GT? Both are similary priced and have similar specs. The older ASCEND maybe going to be discontinued soon? I had ASCEND on my older cars, and liked it, but thinking of trying ASCEND GT.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    I got the GT version and I love them. They did great in heavy rain. Not sure about fuel economy since I got them just as the summer heat hit.
    jb in NE and Salamander_King like this.
  4. bobodaclown
    bobodaclown Member
    216
    72
    Non GT. $68 each.
    Salamander_King likes this.
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I went from the Pirelli Cinturato P7 A/S to the Avid Ascend GT at the beginning of April (April 8th to be exact). The initial hit with the new tires was a loss of 2-4 mpg for the first 1,000 miles or so but by 3,000 miles the tires were already delivering about the same gas mileage as the older tires. I expect them to get even a bit better as the tread wears down over time. The last five tanks have been calculated as 44.11, 42.33, 43.86, 43.3 and 45.12 mpg, right in line with or a hair better than the car's 42.89 lifetime average. I'll know a lot more about them when we return from driving to the East Coast and back in July..
  6. bobodaclown
    bobodaclown Member
    216
    72
    So I've been running the tires about two weeks. I'm liking them. Was running then at 42/40 psi front/rear. Trying 50/48 to improve gas mileage. They are rated to 51 max psi. We'll see how it goes. Ride is a little firmer. The tires replaced were rated for 44 psi max.
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    As the pressures go up, center tread wear also goes up and you beat up your suspension components a lot more. The savings in fuel at these pressures may be more than offset by these costs.
    srellim234 likes this.
  8. bobodaclown
    bobodaclown Member
    216
    72
    I'd agree if we were talking bias ply tires, not radials.
    Tire Tech
    SM-T700 ?
    GatorJZ likes this.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Even radials will narrow the tread pattern at high pressure.
    "Excessive air pressure will cause the tread face to bulge, reducing the contact patch."
  10. bobodaclown
    bobodaclown Member
    216
    72
    Is that pressure over the max rated?
    SM-T700 ?
  11. Mendel Leisk
    41,119
    I think several not so good things can happen at extreme pressure:
    1. Increased suspension/bearing wear. (mentioned by @jb in NE)
    2. Punishing ride. (more so with the low-profile 17's)
    3. Maybe more tendency got lose lose grip over little bumps, especially when cornering?
  12. jerrymildred
    11,517
    14,147
    Tampa, FL
    I'm not sure there's anything to be gained by pumping them over 38-40 psi. If there's any increase in mpg, it'll be well within the range of other influences like weather and traffic, so not enough to be a clear measurement. And the Prime already gets such incredible mileage that I don't fuss about a couple psi and would not want to run my tires close to max psi.
    Another thing I've noticed is that at high pressures the steering gets kind of touchy since the car's weight isn't as even distributed across the tread. It may not wear faster in the middle, but radials don't completely eliminate the tires' tendency to get rounder at higher pressure.
    #12 jerrymildred, Jun 22, 2019
    srellim234 and Mendel Leisk like this.
  13. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    I hope you get lots of miles. Very few get close to the rated mileage claims.
    Making a mileage warranty claim is next to IMPOSSIBLE and oftentimes worthless b/c of the fine print. The biggest impediment against owners, in making a mileage warranty claim, is the requriement of even wear across the tire tread.
    That's some punishing PSI! You have a pretty high pain threshold?
  14. bobodaclown
    bobodaclown Member
    216
    72
    Pressure coming down. 45/43.
  15. Salamander_King
    11,013
    8,942
    New England
    Why? No change in mpg... or you bottom hurts?:LOL::LOL::LOL:
    bobodaclown likes this.
  16. bobodaclown
    bobodaclown Member
    216
    72
    Nah, I did new shocks and struts at the same time. ;)
  17. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Boosting it high doesn't make a lot of sense in my driving conditions. I spend my summers running through the Mojave Desert at 65-75 mph. There may be a 40 or 50 degree difference in the morning between the air temperature in my garage and the highways I'm driving. Driving those conditions adds a minimum 4 or 5 psi. I just try to set them at 38 psi front, 36 psi rear and enjoy the drive without rattling my teeth or facing a blowout. Destroying the suspension, tires or my family is not worth a few mpg.
  18. bobodaclown
    bobodaclown Member
    216
    72
    Lowered the psi 45/43 or so. Tires are great. Gaining the mileage back. Might be in limiting my speed.
    moto g(6) ?
  19. bobodaclown
    bobodaclown Member
    216
    72
    Back to 42/40. All is well.
  20. jerrymildred
    11,517
    14,147
    Tampa, FL
    I have the same tires. Still love them. Had a temporary small reduction in miles/kWh. They are wearing great and still give superb wet weather traction after about 25k miles.
