New to Gen II Prius? Read this blog!!
Discussion in 'Gen 2 Prius Fuel Economy' started by tradermpls, Mar 13, 2013.
  1. tradermpls
    tradermpls New Member
  2. nai1ed
    nai1ed 2006 Prius
    52
    Maine
    There is an old saying about saving gas while driving. "Pretend there is a fragile egg between your foot and the gas pedal"
  3. Former Member 68813
    3,524
    981
    US
    The saying better applies to brakes.
  4. BritBug
    BritBug Junior Member
    This is a great article, thanks for the repost. I have been trying these techniques one at a time from different articles, but I really like how easily it's laid out in this one. I've only had my Prius for 500 miles, and this tank has 300+ miles so far - I'm averaging 57 mpg combined, and am definitely trying! Excited to see what I can get once I master all of these skills but even if I got 57 all the time, I'd be absolutely content. I live in Florida - hot & flat, so I don't have a lot of the problems it talks about but it is still very helpful.
    Thanks,
    Brittany
  5. antif
    antif Junior Member
    I would have to agree. I found that when taking longer to get up to cruising speed by accelerating slowly, I actually averaged less MPG than getting up to cruising speed briskly and pulse-glide to maintain cruising speed when possible. It of course depends on a lot of factors like conditions, terrain, traffic, etc.
    Driving slowly was my initial strategy but then I lost the MPG competition to my wife who kind of naturally pulse and glided. ;D
    Eroshan likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    You can always tell a new Prius owner. There the owners crawling away for the light.
    Data Daedalus likes this.
  7. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    Curious but true! I'm new to the Prius Hybrid and have been generally cruising around serenely and sedately. The other day, I had a spirited dash through London to work and discovered my mpg was actually better than usual :). This Prius Padawan has a lot to learn :D
  8. 800Nm
    800Nm New Member
    About to pick up my prius in two days time, let's see if I will fall into the "sedated" category, LOL!
    Prius_Cub likes this.
  9. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    You will find contrary to normal advice, with the Prius if you accelerate briskly then take your foot off the accelerator then reapply the mpg gets better.
    John (Britprius)
  10. Data Daedalus
    1,022
    1,183
    Wembley, London
    You're quite right John :). I discovered this quite a while ago and have been using it in part to achieve some great MPG. It's turned much colder now in London, and I'm averaging about 56mpg at the moment - down 10mpg from the summer months, but methinks that was entirely to be expected. I'm still very pleased with my 2008 Gen II T-Spirit, and I'm still learning new things about it on a regular basis. I now refer to it as "The Spaceship" :D
    iPad ? HD
  11. Britprius
    5,194
    1,914
    Data Daedalus, The mpg drop is normal, but can be mitigated by blocking the front grill with lengths of foam pipe insulation pushed into the grills just leaving a small area clear if you are driving in London traffic. If you see the outside air temperature going up to say 18 or 20 degrees on the MFD and it's cold outside you know you need to remove a strip.
    John (Britprius)
