New to Prius
Discussion in 'Newbie Forum' started by questhog, Apr 5, 2011.
  1. questhog
    questhog New Member
    New to this forum, new to Prius really. I got a 2011 Prius IV and right now I am getting 33.8 MPG, nowhere near the 50 EPA estimate. Am I doing wrong?
    Thanks.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard! There are many threads on how to (possibly) increase your fuel economy. Use the search option upper right below your user name.
    First thing to check is your tire pressure. They are usually low from the dealership.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Hi Quest! I hope you enjoy PriusChat as much as I do.
    You have not given us much to go on. The USA is a big place with many climates and terrains, so it is hard to pin down your issues.
    Someone made a form to fill out that can give us enough hints to meaningfully give advice.
    http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html
    Before knowing more about your situation, it is hard to give advice that always works.
    The closest to universal advice I can offer is 'inflate your front tires to the load limit printed on the tire itself, and inflate the rear tires 2 lbs less than the fronts'. Toyota's recommendation seems to have more to do with ride comfort than tire wear or MPG. If your comfort suffers, lower all tires by 2 lbs and try again.
    The following graph is true in detail for one 2010 Prius, but true in general for all cars. Wind restance rises with the square of the speed.
    http://priuschat.com/forums/gen-iii-2010-prius-fuel-economy/64296-updated-mpg-vs-mph-chart.html
    One advice I have, if you are on the first or second tank of gas, just drive it. It is far more important to get used to the controls, mirrors, blind spots, and noises than to perfect your hypermiling. On the third tank, try our mileage advice here on PriusChat.
    I hope this offers you enough to tell us in more detail your situation.
  4. krelborne
    krelborne New Member
    295
    Alabama
    Check out this thread for common things that can affect fuel economy. If you answer the questions, it might be easier for people to pinpoint the problem.
    You did reset the trip after you took possession of it, right?
  5. bisco
    49,359
    if you are on your dealers tank of gas, ignore it. when you fill up, reset your trip odo and when you fill up again, divide the gallons into distance for that tank to get a better mpg average. all the best!
  6. questhog
    questhog New Member
    - Have you read Yet? YES
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations) TRIP COMPUTER
    - What fuel economy are you expecting and why? AT LEAST 45
    - What are the approximate outside air temps? About 45
    - How long are your trips? 35 Miles One way to work
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? New car
    Have you had your alignment checked? Any pulling or abnormal tire wear? New Car
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? Of the 35 miles, 26 miles are on Interstate highway.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.) Don't know.
    - What are your tire pressures? Don't know.
    - Is your oil overfilled? (i.e. above the full mark on the dipstick) No
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.) Don't know.
    - What region/state are you in? (if you haven't set your location) Detroit, MI
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking? Try to get close to the "eco" leaf.
    - What modes are you using, if any? "normal", EV, power, eco? Eco, never power (pointless to buy a prius)
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on? Not really, do I have to?
    - Are you driving using D or B mode? D, don't really know what B mode is.
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to? No
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15). Yes.
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute? N/A
  7. questhog
    questhog New Member
    sorry, i had to remove the urls because it wouldn't let me post it.
  8. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  9. fuzzy1
    10,141
    The missing answers to the speed and tire pressure questions seriously hamper our feedback. Please add more detail.
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you were in Colorado, as an example, you might go down some really long inclines that fully charged your battery. The B (for engine braking) mode would be useful there to help prevent the disc brakes from overheating. In Michigan, (like Mississippi) you may be best served to ignore it entirely.
    The highest point in MI is on the U.P., which is cheating.
  11. vday
    vday Member
    312
    Israel
    Is that calculated or on the screen?
    Is this your first tank?
  12. questhog
    questhog New Member
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? Of the 35 miles, 26 miles are on Interstate highway. Speeds are 40 local, 70 hwy.
    - What are your tire pressures? Whatever the recommended pressure is.:)
  13. questhog
    questhog New Member
    Is that calculated or on the screen? It's on the screen, I haven't used a full tank yet.
    Is this your first tank? When I test drove the car, it was almost empty, dealer filled it full when I bought it.
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I REALLY advise you to begin worrying about mileage on the third tank, You should be learning the car. But here is advice any way.
    Drive as if you had no brakes, start coasting when you see the light change, coast up to stop signs, use the brakes when mileage is not important. (safety, courtesy) Long gentle braking recovers more energy than hard braking.
    When the speed limit is 40 MPH, try not to exceed that. Above about 41 to 43, the engine HAS to run, below 41 the computers could decide that it can shut down when coasting. The exact MPH varies by Generation.
    When the dealer filled it, did YOU reset all the counters? In my gen II, they keep averaging previous tanks until you reset them. You may still be stressing over 'demo' miles per gallon.
  15. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi questhog,
    If you have to stab at the brakes, to avoid colliding, your (note my detroit slang? my dad hates that all us kids picked that up there) not regenerating any power. The Prius has a system similar to Mercedes cars, where it fires the brake pistons into the rotors with pressure, to minmise brake activation time. When its sensing a quick brake pedal application, it goes into this mode, rather than electric braking. Following a little further back avoids that issue.
    Additionally, the Cruise Control can get into a high usage mode, if it has to go to WOT (wide open throttle) to maintain speed up a hill for example. At 70 mph cruise, that could happen, and then the car is locked into this mode (under cruise control) After you get up the hill, drop out cruise and get the throttle all the way back then resume, to cancel this high usage mode (per Hobbit's comments on his website). Then you can resume cruise.
    Similarily, if your flooring the acceleerator, your going to need to get all the way off the gas pedal for a few seconds to reset the car out of the high fuel usage mode.
  16. bisco
    49,359
    make sure your earl is not above the full dot on the dipstick?
  17. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Hi questhog - and :welcome:!
    I would read this for starters and apply to your driving style whatever fits, is appropriate, you feel comfortable with.
    Then you might want to adopt more aggressive techniques (so-called "hyper-miling" tips) if you want later and get a hang of it.
    I simply want to drive my car and I want technology to solve problems, not the other way around, so I am not doing any "esoteric" driving... :)
    Terrain and commute type play quite a role, as well as ambient temperature, as you see from my signature I don't have a "stellar" overall MPG, but I still get the occasional 4L/100km-58mpg (displayed) and considering the car size, MPG, that is it not diesel, etc.etc.etc. - I have nothing to complain. Plus 90% of my driving is in town.
    Plus you need to break in the car - that takes about 1000miles. It will get better.
    Regarding "B" mode - please read this - it should answer your current and future questions about the car all in one place. Additional pics with descriptions, here.
    If you still believe that your Prius is not doing good, read this - it gives perspective and avoids "freaking out" after a while... ;)
    Let us know if you see any changes (hopefully!!!) after following all the hints above from me and other fellow PC users.
    Enjoy the ride, relax (and you will - read this... ;) )
    PS: the display is 6% optimistic on average (as per feedback from many different users worldwide) - so if 33.8 is what you have on the display, you are actually doing about 32 (!) - don't worry, it is normal and it will get better. Think about it - if you were driving a similarly size car, with similar performance, in the same way you are driving now the Prius, you would probably get mid-20s mpg...
  18. pakitt
    2,173
    1,311
    Colorado
    PS: this is also useful as a very generic guideline of what to expect from a Prius Gen 3.
  19. questhog
    questhog New Member
    I am now in the 43ish range. Thanks everyone! I am happy with the 43MPG because I drive mostly highways and I know that Prius isn't really for highway driving.
  20. questhog
    questhog New Member
    Also when I am driving 40ish, the realtime MPG indicator is saying I am getting 100MPG. Does it mean I am using electric only? Also is the hybrid battery the same as the battery used to start the car? Is it possible to use up all the battery juice when using electric only?
