New to us 2007 package 1 gen II
Discussion in 'Gen 2 Prius Accessories & Modifications' started by FCguy, Feb 21, 2013.
  1. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Good Afternoon Fellow Prius chatters!
    My Girlfriend and I were recently involved in a somewhat serious car accident. I attached a photo of her 2007 Toyota Matrix.
    We bought a 2007 Prius with ~60k miles to replace it! The car is in great shape.
    Now it's time to get to moddin!
    Top of my list to do very soon:
    EV mode button
    Third break light flasher
    Oil change (I don't trust oil in used cars ... at all)
    OEM backup camera install
    I've been unable to find the EV mode button with Sigma auto. I would like to find the button that goes into the factory option spaces next to the dimmer control. We plan on having this car for a long time so quality of mods is a high priority. Any help on finding the switch?
    For the third light flasher I would like to find a model that flashes the high mount brake light several time and has a reactivation delay of no more than 5-10 seconds. I have found this one that is at the upper limit for the reactivation delay.
    Universal Brake Light Flasher/Strober - 1800+ modes [unvbrkflsh1800] - $24.95 : 3rdBrakeFlasher, E-commerce web site
    Anyone have any suggestions otherwise?
    Oil change. I have yet to look up the proper oil but I've been told 0W20 full synthetic. What would be a nice top of the line filter? What mileage are you guys going on synthetic before replacing the filter/oil/both?
    Finally the backup cam. I've read you can simply install one to Prii that have the updated screen from the early models. I've also heard that you can't. So which is it? Can I install the factory backup cam without a massive headache or massive hole in my wallet?
    Also taking suggestions for mods!
    JMD likes this.
  2. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Oh if anyone is wondering a 21 year old in a 2010 Camaro ran right out in front of us while we were traveling in the left hand lane of a 4 lane highway. He was coming out of a shopping center trying to turn left by crossing our path. His fault of course. He tried to tell the police that we accelerated in order to hit him on purpose :ROFLMAO:
    51,154
    congrats on the prius! glad no one was hurt in the accident, that looks bad. all the best!
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Congrats drive it in good health. Would change the oil and filter straight up and have the dealer do a multi point inspection comes to mind.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I suggest you forget the EV mode switch. It is of very little benefit. All the electricity you use has to come from the ICE. Just let the Prius manage the HV battery for you.
    A better use of your money is to replace the 12 Volt battery. If it's still the original battery then it's probably very marginal. The 12 volt battery can fail with out warning and a replacement is hard to find.
    JMD likes this.
  6. JMD
    3,779
    1,282
    Good advice.
  7. JMD
    3,779
    1,282
  8. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Congrats and welcome to the Prius community. From my research I would also suggest not going with the EV switch. The health of the HV battery is best managed by the car computer system. Otherwise, the long term health is likely to suffer, along with your wallet.
    In eastern North Carolina I use 0-20 Mobile 1. Haven't gotten to the first change of this but expecting to go 10,000. The pointer in oil refill is to absolutely do not allow it to be overfilled, any, at all. Better for it to be a little below the full mark.
    Keep learning about the car here in PC and enjoy.
  9. pjc
    pjc Member
    139
    46
    Bloomington, MN
    I will have to disagree with the advice on the EV mode switch. If it is used sparingly it can be quite useful. Even when my PHEV kit isn't operational, I still use it quite often -- mainly to force zero-gas glides when I am in S3 and under 34 mph. A good rule of thumb would be to not use it for acceleration. If nothing else, it is nice if you just have to move your car a very short distance (across the parking lot, or into the street from the garage, etc.), then you can avoid the S1 warmup cycle and you use a minimal amount of battery juice.
    The point is well taken, though: unless you convert to a PHEV, general driving in EV mode is not recommended.
    My suggestions for additional mods (see links in my signature):
    • Tachometer
    • ECT spoofer (I would wait to do this until you are more comfortable with how the car operates under normal conditions, though)
    Yes, do lots of reading here on PC -- there is a lot to learn about these marvels of engineering.
    (If you didn't understand the talk about "S1" and "S3", look up "The Five Stages of Prius Hybrid Operation")
  10. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Thanks for the responses everyone.
    Despite the negative press above I'm defiantly doing the EV mode mod. Our apartment complex is fairly large and the ICE kicks on for 2-5 seconds on two small hills on the otherwise flat drive. I would like to prevent these ultra short and unnecessary start ups as well as leave the battery in a mid level state of charge so that the warm up cycle can charge the HV pack. I can foresee when a tiny hill will only make the ICE start up for a moment whilst the computer cannot. I plan to use the EV button when appropriate. After what I've read I'm quite the believer that educated use can net a small gain in efficiency and reduce wear on the ICE.
    So I've seen no word on installing the OEM backup cam. Anyone care to help out? Provide a link?
    Also, has anyone done the 3rd flasher mod?
  11. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Anyone? also would like to swap out some/all of the interior bulbs for LEDs.
  12. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I'm glad everyone was able to survive the accident without serous injury. I love the Prius in White! Welcome to the forum.
  13. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    I'm disappointed that I haven't seen more feedback.
    What I've found is as follows.
    TL;DR version - Backup cam. Looks like you cant just hook up the back cam. Probably use Coastaltech lockpick and ebay cam. Not sure if factory wiring is present. EV mod - Sigma button is cool but expensive. I'll go with Coastaltech's cruise method. 3rd brake light - I'll go with the link in my first post as every other one has too long of a reactivation delay. LEDs - This is way complicated. I have no idea how I'm going to figure out what fits/performs well in each location.
    Full version -
    Backup Cam:
    This post seems to suggest that 06+ Prii are pre-wired for the factory backup cam. I also found that Coastaltech sells a 'lockpick' for 06-09 base model Prii here (scroll down and find "CLICK THE BUTTON BELOW IF YOUR 2006-2008 PRIUS IS THE BASE MODEL WITHOUT NAV, JBL AUDIO OR FACTORY REAR VIEW CAMERA"). I've found an OEM Prius cam for $130 on EBay. Between the $230 lockpick and the $130 cam I'm now finding it a bit hard to swallow. The first link I ... linked ... shows where the 05 owner gave up and got a rear view mirror screen. On Ebay it's over $600 :eek:!!!!111oneeleven. HOLY CRAP. So the evidence seems to be that the coastal mod using this $20 Sony back up cam (also used by another 05 owner on the second page of the same first thread above) is the smartest/least expensive route. It would be nice if I could use the factory wiring so I don't have to run my own ... if it truly is already there. I really need to pull the trim off in the area to see if the wiring is there or not.
    EV mode mod:
    Sigma's EV button is $85 alone ... they stuck it in the interior section rather than the "12 volt" section ... stupid me for not finding it in the first place. I figure that the Coastal mod, while not what I first wanted, will be cleaner, cheaper ($45), and easier to install.
    3rd Brake light:
    The link I first used will likely be the way I have to go. I have not yet researched this ad nauseam but I might ... the linked one seems to do what I want but has a WHOLE lot of other settings to play with that I don't necessarily need. I don't think I'm going to truly find what I want otherwise (flashes X times then solid, reactivation delay of no more than 10 second).
    LED interior lights:
    I first need to add to this. I would also like to find/install LEDs for both the license plate lights and the rear tail lamps (not the brake lights lol). I haven't been able to find much on this subject. Plenty of bulbs but no real guide as to what goes where factory bulb wise much less which of the MANY offerings for each bulb type will fit/perform well for each particular location. This one is turning out to be much tougher than what I anticipated. I'm just hoping I can find a kit pre sorted for a Prius. This kit is insanely awesome but is unfortunately for Gen IIIs.
  14. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    Go to this address for a great led kit for 28$
    Toyota Prius 2004-2011 LED Interior Package Deal
  15. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Awesome!
    Did you use these? Any note on the license plate LEDs they also sell?
  16. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    I have them on my Camry. And ordered them for my Prius. But saw a better deal on ebay for a better style of lights for 10$ cheaper. I will try to find the link.
  17. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Any luck finding that link?
  18. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
