New Traction Battery, Engine Running, MFD Not Displaying, Low MPG
Discussion in 'Gen 2 Prius Main Forum' started by Jqwl, Jan 17, 2025.
  1. Jqwl
    Jqwl New Member
    Bay Area
    Hi all,
    2 weeks ago, I had a new OEM Toyota Hybrid Battery installed in my '08. Afterwards, I flushed the pistons with B-12 solvent (according to some threads here), changed oil, installed new spark plugs, and cleaned the MAF.
    Immediately after performing the flush, the Red Triangle flashed on + check-engine light. After driving around and parking, the Red Triangle went away, but still check engine: P3190, which I cleared.
    Now , the car fluctuates between two states. Normal state, which is great. Low MPG state: the ICE motor runs a lot, MPG seems lower than usual, and the ICE motor even runs when the MFD says it's not running.
    As in, with only Blue Recharging arrows to the Traction battery, the ICE motor is still audibly running and my MPG reflects that.
    Anywhere from ~5 MPG to ~80 MPG with the ICE motor still on, but the MFD says "recharging" (usually 99.9 MPG). When the car correctly shows the ICE motor on, I get low MPG. Average around 35.
    Sometimes the car switches to normal mode, and drives great and normally.
    I'm confounded, but happy to be here. What can I do?
  2. Jqwl
    Jqwl New Member
    Bay Area
    Some important context: The weather is cool, but not that cold. 44 F low and 54 high. I've read some other forums that the car might likely be trying to warm up. However, I'd expect the car to be warm after 15 minutes or so of driving and thus not exhibit the low MPG behavior- which it seems to do.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,637
    788
    Southern California
    Brian1954 and PriusCamper like this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,047
    1,974
    NJ-USA
    What scantool do you have? Can it scan all 15-16 systems for codes? What does ECM (engine) data look like? Specifically, what are short and long term fuel trim values at various driving conditions? (Hot engine running- at idle, light accel and 50+mph cruise).
    This can give a basic picture of engine function.
  5. Jqwl
    Jqwl New Member
    Bay Area
    I was using a generic OBDII that my neighbor owns. What do I need to collect ECM data?
    I'm quite curious to get to the root of my "poor" MPG.
  6. Mendel Leisk
    41,457
    Did you test drive after the battery replacement, or dive right into the other stuff?
    hey join the club. :)
  7. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    OBDII is a way to connect to the car's systems. What software is used on the phone?
    See this topic.
    Gen2 OBD2 app review | Page 2 | PriusChat
