New user, new thread, new challenge!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Simon the Frenchie, Dec 11, 2012.
  1. Simon the Frenchie
    Simon the Frenchie New Member
    Hi everyone,
    First of all; presentation! Who am I? And why do I speak so weird?
    As my name says it I'm French and I take it as a big enough excuse for the way I speak.:)
    I'm seriously interested by EV for the last 2-3 years, and have been searching a lot on internet about how to convert a gas car to electric power. Study quite a bit by internet searching, forum, video... 21st century study I mean. So my project become to have a electric car as a first car, did I forgot to say I'm 21? yeah maybe I did, but in France having a electric car means "buy a brand new electric car with renting battery and bad range". No way in France to convert your car, you'll be illegal, couldn't register and insure it.
    But, because there is always a "but", extend battery pack from a prius isn't illegal, enough for me to change my plan to prius battery extension.
    Ok presentation more or less done, I already see some of you getting bored, don't worry here comes the challenge;
    I haven't bought my prius yet, should be done on January and be a 2006 model (European model so Ev mode button present).
    I want to put a good amount of kw in my trunk, during my research for ev converting I found the best price/Kw at Balqon.com. Those are LiFePo4 cells from Winston. Trustable website improved by several users of diyelectriccar.com where I'm also active as the same name I'm here.
    Because I can get 10Kw from them way cheaper as from a already made kit I wanted to make a homemade kit.
    For hacking the prius ev speed limit I can get Hybrid Energy Manager from Ewert Energy for 70mph electric mode and about 400-500$.
    Here are missing some parts; converter, controller, charger and all the techniques that I'm more or less ignorant about!
    Did anyone made is own kit? Is it worth doing it?
    Hum... I think I got it all... Oooh I forgot, I would like to do it first on my own futur-prius and then depending how it works making it my permanent job!
    Thanks for all the ones that read it all, hear from you!
    Simon
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Hi Simon and Welcome to PC! Curious about the range (distance) you might have with the higher EV speed?
    49,504
    bienvenue simon, there are plenty of threads here discussing ev conversions. all the best with your project!
  4. ETC(SS)
    6,556
    Salutations!
    Bienvenue sur Priuschat.
    Pas besoin de vous excuser pour votre anglais, car il est beaucoup mieux que mon français! En fait ... j'ai dû utiliser Google Translate pour en arriver là, depuis mon lycée français est seulement bon pour localiser les toilettes.
    Bonne chance!
  5. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Welcome to Prius Chat!
  6. usnavystgc
    3,159
    989
    Tucson, AZ
    Converting the Prius as you depict is not a good idea. The Prius is not a good candidate for EV conversion for many reasons.
    1) It is designed as a gasoline (primary) car with electric assist. It is for this reason that the electric motors do not have enough power to safely propel the car. With electric mode only, the car is really underpowered and not safe to drive on the streets
    2) The Prius has advanced, high-tech monitoring systems (called ECU's) that all work together to make this engineering marvel work. Adding more battery capacity requires modifying what one ECU sees which causes multiple problems with other ECU's.
    There are other numerous reasons why the Prius shouldn't be converted unless you're going to gut the HSD and add an electric drive system that can handle the requirements. The stock Prius electrical system cannot handle the requirements on its own. It needs the gas engine and the gas engine needs the electrical system. They have a symbiotic relationship.
