New waterless carwash for all vehicles
Discussion in 'PriusChat Shop Forum' started by changingsyntek, Dec 8, 2009.
  1. changingsyntek
    changingsyntek New Member
    texas
    2002 Prius
    there is a new eco-mist waterless car wash for people who don't wanna waste water or its too cold to wash ur car outside.. i will be posting it very soon
  2. scottwyden
    scottwyden new jersey photographer
    342
    New Jersey
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Can you list the ingredients in the eco-mist?
    I am not sure if I want to have the chemicals left on the paint finish.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    It's comparable to using 260 grit emery paper......
    The main reason for WATER is to loosen and flush the grit away and remove it before it SCRATCHES the HELL out of the Clear Coat!!!
    This stuff might be OK AFTER you wash the car as you should, but as is...NO WAY!!!
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Now, now, maybe the OP has come up with something that dematerializes dirt and grit so all you have to do is spray and ZAP! it's gone! After all, it must be realy something if he is going to tell us about it "soon" and can't just post it outright, right?
    :rolleyes:
    :crazy:
    :twitch:
    :der:
    :huh:
  6. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I read Scott's review about Eco Touch mist spray.
    Personally, I wouldn't use the stuff.
    1. I don't like the BS that it's "waterless". It's not. It's a spray solution that must have liquid (most probably water) in it. And I doubt that that's enough water and that Eco Touch has enough lubriosity to avoid or minimize scratching of the clear coat.
    2. If you don't have access to a hose or there are water restrictions where you live, I think the better practice is to use Optimum No Rinse Wash and Shine.
    With Optimum No Rinse, I only use 1 or 2 buckets of water depending on whether I use the 1 or 2 bucket method, i.e., one bucket for the Optimum No Rinse mixed with water and, at my option, a second bucket of clear water to clean the wash mitt.
    This means I use 1.5 to 3.00 gallons of water to wash my car. This isn't much water use. And after using Optimum No Rinse for about 2 years, I haven't noticed any scratching of the clear coat.
  7. KK6PD
    4,003
    944
    118
    Yeah, thats the same company that came up with that pill that lets you melt away the pounds as you sleep.....:D
    SWEEEEEET!!!!
    I also think BOO is "Spot On" (Pun Intended) with his comments!!!
  8. PriusLewis
    1,002
    84
    Denver Metro
