New way to stop the Prius
Discussion in 'Gen 2 Prius Main Forum' started by chuckknight, Mar 16, 2010.
  1. chuckknight
    chuckknight New Member
    194
    33
    I had not thought of this...saw this as a comment on a YouTube video, and it's ingenious.
    Wonder if it would really work? Is the key necessary for the car to *run,* or only for the car to *start?*
    Chuck
  2. the hosser
    the hosser Lock Monkey
    37
    Pennsylvania
    A car dealer told me that the car will keep running, just beep at you the whole time... never tried it myself, but it seems like if the fob battery died while it was in the car, the car would keep working.
  3. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    The car will continue to run but once turned off or ran out of gas you would be stranded.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    As an adder to this, if you want to try this experiment anyway, be sure to put a big a** tag on your keys so you can find them again. They are expensive to replace :)
  5. chuckknight
    194
    33
    The SKS tracks the location of the key. If the battery died while in the car, the last known location would have been *in* the car.
    If you chuck it out the window, the last known location would have been *outside* the car.
    It's an interesting premise.
  6. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Yes, I have tried walking away from my car while it was still in "Ready" carrying the fob. The car complains a lot! It "beeps " all over the place. It DOES NOT LIKE that. But it does not turn off until YOU turn it off.
  7. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Yes, car will keep running. Actually, people have accidentally gotten out of their car with it in ready mode (meaning running), gone in to the house for the night, come out in the morning and their car is still in ready mode. The car will still be functioning, although the ICE will come on occasionally to keep the traction battery charged. It will beep at you when you get out, but if you are hard of hearing or in a noisy environment you may not hear it.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    As stated above, the key fob is only needed for starting the car, not running it. It will run indefinitely without the key fob once started. Of course, without the fob you won't be able to restart it once powered off.
    This has led to a few embarrassing situations where someone has dropped off a spouse and continued to another city, only to learn that the fob was in the possession of the spouse: "Honey, can you come and get me, or perhaps overnight the keys?"
    Tom
  9. w2co
    w2co Member
    366
    81
    Longmont, CO.
    My 06' beeps three times when I walk away into the store for a min, in park but ready, always in sight of course. Then when I come back it stays quiet and ready. Actually the only warning is the drivers seatbelt blinking I noticed, but when you get in again it all goes away. Have not tried to walk any farther than 50' but through a wall. That's interesting that it could drive off very far as long as they don't shut down or run out of gas. I have the security package, will look in manual for capabilities..
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    On my 2010, I get the three beeps plus I get an error message on the MID that says "Key Not Detected" when I get outside of the car. The car does continue to run.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Yes. Someone can get in it and drive it across the country without the key.
    Tom
  12. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    Long as you don't shut it off, it will keep running without the fob any place close.... done it a few times.;)
