New Wiper Blades for 2012 V ?
Discussion in 'Prius v Accessories and Modifications' started by fpfpfpfpfp, Dec 5, 2024.
  1. fpfpfpfpfp
    fpfpfpfpfp Junior Member
    United States
    Couldn't find any help in the manual about replacement. No how to, nothing about size, or how to know if I only need to replace the rubber, or the whole arm thing.
    Do I need to replace the whole thing? How do I know if I need to or not? ..or just the rubber?
    Is this worth spending high $ on, or could I get away with smth cheapo under $40
    Doing some quick and dirty googling, seems like Bosch or RainX are common go to recommendations.
    Was considering going to a local auto parts, but idk if that's a good idea. Would prefer that, if the prices and selection are ok, bc I'd like to not wait for a delivery.
  2. BiomedO1
    BiomedO1 Senior Member
    4,155
    2,176
    SacTown, Ca
    You'll probably have to go to an auto parts store, because we don't know what you have. I doubt that's the original OEM wipers still there. The OEM, you can just replace the rubber. If someone replace them with after market, some rubber can be replaced others require the entire unit to be replaced.
    Good Luck....
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,521
    6,604
    Texas Hill Country
    Option 1
    If you have original blades keep them and replace the rubber (inserts). Overall the best and lowest cost at the same time. You can buy all three from a local dealer for $25 msrp. Ask for a discount as well. It works at a good dealer.
    Toyota wiper rubber insert part numbers:
    Front
    85214-47061
    85214-47051
    Rear
    85214-12310
    Option 2 Quick Connect Blades with inserts preinstalled
    Buy the oem blades which are easier to install but pricey. You get new paint on them if yours are faded. Buy these at an online dealer for 25-48% off.
    The original blades are aero and you won't get that with aftermarket. Aftermarket blades are easy but not oem. Usually clunky looking.
    Toyota Blades part numbers:
    Blade, Front Wiper, LH 85222-47040
    Blade, Front Wiper, RH 85212-47060
    Blade Rear Wiper 85242-12090
    Option 3 The Spring Loaded Arms
    The Arms are the piece that attaches with a nut - rarely needed and may be original even if someone put on aftermarket blades
    Arm, Front Wiper, Rh 85211-47140
    Arm, Left Wiper, LH 85221-47120
    Comments
    Some like to use inserts in front and a blade in the rear as the inserts are a bit tricker to install on the rear
    Installing - Call a Friend or Watch Videos if necessary
    A screwdriver might be needed.
    The trick to remove and replace rubber inserts:
    Four latches lie in a metal groove that mounts the rubber strip. To remove, pull up on the rubber strip from the middle to free the last latch. Replace in reverse by threading the latch 3,2,1 and 4 last. It is easier to remove the assembly from the car rather than trying to fit the replacement in place. If necessary get a teenager to do it or watch a video.
    Aero OEM Blade
    Arm and Blade
    Arm with Spring
    Blade with Preinstalled Rubber Insert
    Rubber Insert
    There are two narrow metal strips that fit in the top grooves above. You reuse them if installing rubber only.
    When you have driven and maintained a 320,000 mile gen3 from day one you end up with good spares and knowledge 60k garage queens will never provide their owners.
    #3 rjparker, Dec 6, 2024
    fpfpfpfpfp, BiomedO1 and Mendel Leisk like this.
  4. fpfpfpfpfp
    United States
    yea, i have the original aero blades. i double checked, too, just to be safe
    shocked that the dealer ends up being the best deal. looked them up on amazon and it's nearly $40 for all 3
    but, if i read you right, ur saying the rear is hard to replace DIY, so buy the entire assembly?
    not sure i follow ur directions
    i'd like to try and diy.
  5. rjparker
    10,521
    6,604
    Texas Hill Country
    Like I said, find a teenager or video. Once you have them in your hand most people can figure it out. There are metal strips that hold the inserts in you don't see in my old parts.
    Once you have succeeded once its a 15 minute or less job in the future.
    You can do the rear inserts as well; its just slightly different because of its size.
    I could find a video for you but finding videos is a skill you should master.
    Top tip:
    The rear blade and arm are removed as one piece. Remove the cover and the nut. The rear blade/arm fits a little tight.
    #5 rjparker, Dec 6, 2024
    fpfpfpfpfp likes this.
  6. Air_Boss
    Air_Boss Senior Member
    4,225
    1,188
    New Yawk
    The rear blade replacement process on the Honda CR-V starts the same way….
  7. Mendel Leisk
    41,909
    Yeah this is a fail from Toyota; it SHOULD be explained in Owners Manual. Attached are some “behind the paywall” excerpts from the third Gen Prius Repair Manual (hopefully similar for Prius v).
    A tip, might save your windshield: before removing a blade, look at where the tip of the spring-loaded bare wiper arm would hit the windshield if you were to let go of it, and place a rolled up towel there.
    fpfpfpfpfp and Air_Boss like this.
  8. rjparker
    10,521
    6,604
    Texas Hill Country
    Don't get scared off by the repair manual pdfs.
    The pdfs are about removing the entire wiper arm and continue down to the wiper motors. Not necessary for wiper blade removal or insert replacement.
  9. Mendel Leisk
    41,909
    Yeah, see for the most part it's not relevant. The rear wiper one at least is helpful.
    Honda Owner's Manuals have wiper insert replacement info; Toyota drops the ball.
    I remember going to a New Owner thing at our Toyota dealership, the service manager sheperded us through the service department, made as statement, paraphrasing "our goal is to make it so you never have to pop the hood".
  10. fpfpfpfpfp
    United States
    ok, well, that's encouraging. great! ..i'll try and find videos.
    thx!
    but, im still confused by your seeming fixation on teenagers... are you assuming I'm 114 years old? i dont understand whatever this is about lol
  11. fpfpfpfpfp
    United States
    ah, a towel. sounds good.
    yea, ridiculous that they only mention how to operate the wipers lol
    thx for the pdfs!
  12. fpfpfpfpfp
    United States
    also, i'm wondering where youre getting 25$ MSRP
    i called around the dealers and they told me $14.99/ea and w tax coming to around $50
    is this bc you assume they'd give me a discount?
  13. fpfpfpfpfp
    United States
    well, i bought em. i was able to get them to discount it but not the $24 that you mentioned. $36ish total
    i was surprised to learn tho, he told me, they are only meant to last one measly year... my first hint of buyers regret lol
  14. Mendel Leisk
    41,909
    I replaced our '10's front wipers maybe around the 10 year mark, just the rubber, from Toyota. The old ones still looked fine. Have yet to do the rears.
    Incidentally, I noticed gen 4 Owner's Manual now has instruction for wiper blade replacment, a nice addition. It's hopefully similar, so I've attached an excerpt:
  15. rjparker
    10,521
    6,604
    Texas Hill Country
    The gen4 rear instructions are pretty close to a gen3 but the fronts are quite different.
    There are gen3 instructions in the repair manual floating around someone's signature. Its just tedious to locate in a 7500 page pdf without links. Especially if you already know how to do it.
    I also find the Toyota rubber inserts last many years - I avoid using them as a windshield cleaner which tends to trap debris between the rubber and the window. Occasionally if a big bird does his business on it I will carefully saturate the windshield with wiper fluid without engaging the wipers, multiple times, ideally wait a minute (soap does it work over time) then engage the wipers along with more fluid.
    If you can't get a good price from the dealer, buy from online Toyota dealers. Often I can get free ship to store for any quantity and simply pick up at the dealer. Otherwise buy your wiper rubber, air, cabin and oil filters in enough quantity to get free shipping.
    #15 rjparker, Dec 10, 2024
