New York State Easy Pass Sticker Removal Question
Discussion in 'Gen 2 Prius Main Forum' started by ronniemu, Jan 31, 2008.
  1. ronniemu
    ronniemu New Member
    Long Island, NY
    I had a problem with one of the four easy pass stickers that I received from the NY Department of Motor Vehicles. They are going to send me new stickers. I need to remove the stickers presently on my vehicle. Has anyone had to remove their stickers. I would like to know if they came off easily and if they just have to be peeled off.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Where are stickers located on your car? If they are on the painted surfaces, why not just put the new stickers over the old ones?
  3. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    Ronniemu - I know this much. When you remove the sticker, a portion remains that has the words 'Void' repeated over the surface. I don't know how easy it is to get the Void portion off the bumper, however.
    Marvin
  4. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    You have to get a window scraper, like what tinting people use, it has a razor blade on it, you spray some sort of soapy water on the glass with the sticker let it kinda soak in and use the razor lightly, if it doesnt come off increase force but be careful not to scratch the glass
  5. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    The sticker is not on the glass. Its on the bumper surfaces. In 4 locations. So a glass scraper cannot be used.
    Marvin
  6. Sanguine
    Sanguine Junior Member
    Central New York
    I would try "Goo Gone" should be able to get it at a supermarket, Walmart etc. in the cleaners aisle. I have heard of people using peanut butter on bumper stickers, though I have not tried it. Mineral oil might be worth a try.
  7. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    You may want to try heating it up with a hair dryer and then gently peeling it off (or scraping it off).
  8. Doc Willie
    1,717
    142
    Out there, somewhere
    In a pinch, WD-40 may also work.
  9. Sanguine
    Central New York
    So,
    Inquiring minds want to know. What worked?
