Newbie (be gentle!): How do I wax my baby?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tarapup, Mar 21, 2008.
  1. tarapup
    tarapup Junior Member
    Twin Cities, MN
    all. I'm a newbie. http://priuschat.com/forums/newbie-forum/44417-just-picked-up-my-08-metallic-grey-yesterday.html
    Please be gentle. I'm usually a "go to the wash, tell them what I want, and wait" kind o'girl. But with this car, I plan to try to handle it myself.
    Okay, at least for now. :p
    I have all the products...I'm prepared. But I don't have the WAX or a clear coat protectant kind o'deal.
    Your recommendations and experience, please?
    Thanks, Mary
  2. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    Check out the ZAINO threads!
    Best stuff I've ever used and very easy!!!!!:cheer2:
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I agree with Barbara M. Zaino is amazing. You won't believe how your car can gleam, and it smells good!
  4. longrider
    longrider soxfan
    methuen ma
    I'll 3rd on the Zaino products. That's all I use on my Corvette. It's not a wax, but a polish and boy does it work. Some people find the instructions a little confusing but I highly recommend it. I'll never use wax again.
    No matter what you decide, you'll want to start out by "claying" your cars finish. It's very easy to do and the clay bar will pull surface contaminants out of the paint so you have a nice clean surface to shine up. I think McGuire's and Griot's websites actually have videos you can watch to see how it works.
  5. Tideland Prius
    16,445
  6. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    your probably going to get a lot of responses and plugs for zaino
    on this one!!!!
    consumers reprorts reccomends only using spray on wax on a new car
    and a non abraisive wax like black magic (8.42 a bottle on amazon) is rated highly
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I use Turtle Wax, cotton cloth and Elbow Grease.
    Wash and dry the car in the shade with a good car wash, I like Turtle Wash. Leave the car to dry for an hour after using a chamois to remove as much water as possible.
    Put wax on clean rag, rub onto the panel in a circular motion making it look dull, add more wax to rag if needed to cover the panel, allow to dry then using a clean cloth buff to a mirror shine.
    Avoid getting wax in rubber parts.
    Start with the roof, bonnet and hatch then at a corner and work around the car.
    NEVER polish in the direct sunshine or if it is really hot.
    Repeat once or twice a year depending on your environment.
  8. strider5
    strider5 New Member
    Philly
    I've been using Zaino for years on various cars. no offense, but forget elbow grease and waxes that only last a month or two.
    I switched to Zaino Z-CS not long ago and really like it. even easier than Z2. you spray it on like windex, wipe it around and let it dry. no removal necessary.
    expensive, but what is your time and "elbow grease" worth? ;)
    I find that zaino lasts about 6 months. it is NOT a polish though, so it is best if you start using it when your car is new, otherwise you will need to polish out swirlmarks and then apply. zaino on top of swirls will just end up in a really shiny swirled car :(
  9. rigormortis
    1,340
    26
    san jose, ca
    turtle wax wasn't rated highly, its really one of the more
    abrasive automotive waxes
  10. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    ao over to autogeek.net
    they have a ton of stuff. Since your car is new it wont really need a polish, although some would say to clay a new car..it wont hurt anything just be sure you use plenty of lubrication, like mequiars OD. Wash car first, CLAY(this only needs to be done twice a year imo) What I do is this in order. 1.)Pinnacle XMT claze polish #1, very fine. 2.) coat of techwaxNXT paste..and usually call it done then, the NXT will take some time to "set" depends on your climate. You can top it off with a carnauba wax to really make it stand out. Never used Zaino, but hear it's the bomb. Most of these products are very good quality, and I gotta say techwax does last, and for quite a while..normally 3 months in paste form.
    Just be sure to wash properly and you should be fine in regards to swirls, your always gonna have a few here and there, but dont loose sleep over it. I have a black car and it can drive you mad. Im thinking of picking up the porter cable DA for the swirls one of these days.
  11. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I have a "06 and used 5Star Shine PPS, a silicone based coating. Have never had to re-apply since August of "06, still beads up and dirt just kind of falls off. Very expensive. See the advertisement on Never Wax Your Car Again! - 5 Star Shine
  12. mmichaell
    mmichaell Member
    241
    chicago
    How's that 5Start Shine working for you? I'm looking for a car coating that easily repels dirt or washes off easily, since I have a 2010 White Prius.
    Thanks!
