Newbie breakdown - help!
Discussion in 'Newbie Forum' started by David Bloom, Aug 15, 2014.
  1. David Bloom
    David Bloom New Member
    2001 Prius
    Bought my 2001 in January, best car I've ever owned. 76K original miles, cherry, $5800. I'm 6'5" 205, my Prius is surprisingly comfortable and (not so surprisingly) responsible transportation. Getting 49+ mpg on daily work trek, 48 miles there & back (47+ mpg when running the A/C). Easy handling in the Colorado ice & snow Jan-Apr. Yesterday, was driving 35 mph in traffic when suddenly everything went black. No lights, power, indicators, absolutely nothing. Towed home, sitting in the driveway. 12v battery checks out, gotta be a fuse or relay, right? Anyone know which one(s)?
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Welcome to PriusChat; lots of helpful folk, only too willing to share everything you'll ever need to know about Prii. From your description, it sounds the problem might be electrical, and a fuse, relay or bad connection might be leading contenders. Have you had a chance to speak to your mechanic/dealer? Are you a member of AAA? BTW, you might want to put your location in your information (allows others to recommend/suggest good dealers/mechanics (OK, I realize that sounds like wishful thinking! :rolleyes: ), anyway, welcome and good luck with your Prius - Wil
  3. Southbound
    Southbound Member
    91
    29
    Palos Heights, Il
    Has the traction battery been replaced.?
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    How exactly does the 12 V battery "check out" ?
    With no load on it, it can look good when it is not.
