Newbie downloads TIS manuals
Discussion in 'Newbie Forum' started by meus_carrum, Feb 26, 2025.
  1. meus_carrum
    meus_carrum New Member
    Ontario
    2017 Prius v wagon
    After reading some posts about some useful technical sources, I was able to download the repair manual and wiring diagrams from TIS after buying a 2 day subscription and using this process described on a git hub page (fetch-toyota-service-manuals). I can't post the link because my post count is too low as a new forum member to post URLs.
    The download took about 40 minutes for everything and creates a file hierarchy that mimics a table of contents: the tree view on the navigation bar of the TIS website. Unfortunately, it was not able to download the BM manuals, a problem reported by other users. Fortunately, I only wanted a few of these anyway so downloaded them manually. I'm still working on a way to modify the internal links which are retained to the original source so not really helpful in the manual even thought the content is downloaded: the link uses the TIS site reference.
    You have the option of printing to pdf, a method described in other threads but this was much easier although it does require some technical knowledge to install the required programs. The set up took longer for me than the actual downloads. It is also a solution that may not be around for long. The TIS system is moving to a 2 factor authentication process and it's likely that the scripts will no longer work unless the author revises them.
    #1 meus_carrum, Feb 26, 2025
    MAX2 likes this.
  2. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Interesting information.
    What is this complex identification?
  3. meus_carrum
    Ontario
    2017 Prius v wagon
    It would be the use of a text message or email. Re-reading it, it looks "opt-in" so my caution about the change and the use of the scripts would be dependent on the choices the subscriber makes.
    "Due to enhanced security requirements, Techinfo will soon roll out a new feature - Multi-Factor Authentication (MFA). This will add more security to your account and means that there will be an extra verification step to verify your login credentials. If you are a new user, after you register, you will be able to add a safe and secure two-step verification method for your online credentials.
    The authentication options with be either a text message or email notification. Therefore, please ensure your account and contact details are accurate and up to date to maintain access to Techinfo."
