Newbie Gen 3 owner: improve MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by Dazzlingdynamo, Jul 27, 2023.
Tags:
  1. Dazzlingdynamo
    Dazzlingdynamo New Member
    Virginia
    Brand new Prius owner. I purchased this OBDII reader.
    I purchased this OBDII reader. I have completed two tests. The battery showed 66% the first reading and 61 % in the second reading a few days later. Should I be looking for a new battery?
    The MPG was 37.7 on the first day of my new hour-long commute. I want to improve this to closer to 50. What do I need to do first to work on improving the MPG?
    We have cleaned or replaced both the battery and cabin filter. The heat here in central Virginia has been ridiculous. I am not sure how much that has impacted the MPG/battery.
    Any suggestions would be greatly appreciated.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    706
    276
    Maine
    Have you checked tire pressure?
  3. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    Assuming you're refering to the hybrid battery...
    You could use the Prolong system to recondition the battery.
    $650 is a lot less than $2000.
    #3 ASRDogman, Jul 28, 2023
    49,488
    welcome!
    how many miles on her?
    what tires are you running?
    have you cleaned the egr circuit?
    how is the 12 volt health?
  5. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Just bought and bam! New hybrid battery needed soon
    Saving gas costs a lot of money
    Kromis likes this.
