newbie: Had problems accelerating from stop
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Crystal S, Mar 23, 2015.
  1. Crystal S
    Crystal S Junior Member
    Colorado
    I've had my Prius for over 3 years now. I've put 90K miles on my 2008 which I bought used. It has about 162K miles on it. The light turned green, I pushed on the gas pedal and it barely moved... took what felt like forever to get to 30 mph... and I only had 1 bar on my main battery gauge. I noticed that is the only time it did it today...but it has never done it before with only 1 bar... it was a little scary. Any thoughts?
  2. a_gray_prius
    2,927
    783
    IL
    Sounds strange. Any warning lights or recent errors?
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    A shop needs to scan it for fault codes.
    And the 12 V battery needs to be tested. If it's 7 years old, it probably needs to be replaced.
    On a car that is 7 years old with over 100K miles, there are a lot of possibilities.......including getting some bad gas.
  4. Crystal S
    Colorado
    No warning lights or errors...
    Just replaced 12V in November. The hesitation going uphill in the morning has been happening for some time. I haven't been able to replicate the not wanting to go from a stop yet, so bad gas is a possibility. I am supposed to drive to Texas in April and May and I'm wondering if I should take it to a Toyota specialist and have them run a diagnostics on it to make sure there isn't anything wrong?
    #4 Crystal S, Mar 25, 2015
  5. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    First sign of a hybrid battery going bad? Get the hybrid battery charged/balanced (grid charger)? Clean the hybrid battery cooling fan? Check the 12v battery again...
    #5 Dino33ca, Mar 26, 2015
  6. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Bad gas? Fuel filter could be clogging up.
  7. bisco
    51,155
    did the engine come on?
  8. Easy Rider 2
    1,584
    258
    Ocala, FL
    My opinion is yes. A can of Techron in the gas wouldn't hurt in the meantime.
  9. Crystal S
    Colorado
    I've looked in the manual and cannot find one page of information on a fuel filter.
  10. Crystal S
    Colorado
    Thank you! I will do that!
  11. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The fuel filter is in the gas tank and is not accessible.
    JeffD
  12. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    PM (Private Message) PriusChat member "3prongpaul". He is in the Boulder, CO, area. And possibly works for Boulder Hybrids?
    Maybe they are close and could run the Techstream diagnosis on your Prius for a fraction of the dealership fee of $100+. I'm sure their labor rates are a fraction of the dealership too. Maybe they have a PriusChat member diagnosis discount fee too?
    #12 exstudent, Apr 6, 2015
