newbie here...recommend for high mileage driver
Discussion in 'Newbie Forum' started by parhead, Feb 1, 2011.
  1. parhead
    parhead New Member
    Columbus, OH
    Hi everyone. I new here.
    Anyway, I have a couple of questions and would like your input:
    1) would you recommend a Prius to a high mileage driver? I put on about 30-40,000 miles per year. I've read posts of people replacing the battery after 80,000 miles and others over 200,000 miles. Im just looking for some additional thoughts and opinions/
    2) Barcelona Red 2010 Prius II...22,000 miles...$18,994 (before negotiations)...in Ohio.
    at what price should I be able to get this car? (there are 2 listed from two different dealers at basically the same mileage and price). Thoughts and recommendations....?
    Thank you.
  2. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    1) YES! 5-6 cents per mile for gas, oil changes every 10,000 miles (2010 forward), no belts of any kind (2010 forward), brake service approximately never, generally low operating and maintenance costs. Just rotate the tires.
    If these are highway miles, you could look also at a HCH or a Hyundai Sonata (or Hybrid) or Elantra, or Ford Fusion Hybrid. Sonata has more passenger room, but the prius hatch is pretty nice for cargo other than sheet material.
    2) No help here...
  3. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    I drive 30,000 miles a year, minimum of 55 miles on a 55 MPH road each way every work day. Once the Prius warms up, mileage is wonderful. I am over 55,000 miles so far I have done oil change and tire rotation at Toyota's schedule and one each engine and cabin air filter. The original tires went about 53,000 miles.
    An observation, those getting HUGE battery mileage are taxis: the car is rarely off, the computers are always babysitting the battery, and they run up those miles in very few winters.
    Those getting small mileage on the HV Battery are those who park the Prius for weeks at a time and do not drive many miles per year, so it sees many winters. Also, Toyota's design after 2003 is better than the 2001 to 2003 battery design.
    I have begun discouraging prospective buyers who plan to let their Prius sit over a week at a time routinely.
    BTW, badly jump starting with a Prius can be much more expensive than the battery. If you routinely jump start others, or routinely need jump starts, the Prius is also not ideal for you.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Uhh, where you have seen people needing HV battery replacement at 80K miles? Failures at that low a mileage are very rare. The HV battery in non-CARB states is warranted for 8 years/100K miles and non-CARB states for 10 years/150K miles. I suppose if you needed a replacement right before mileage expiration, you could consider yourself lucky in that you'd have new one good for a lot longer.
    See the story and watch the video at http://priuschat.com/forums/prius-h...ery-reliable-vancouver-yellow-cab-update.html.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
  6. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Welcome to PriusChat.
    You'll have no problem putting high mileage on your Prius especially since operating costs are very low. Many corporate fleets are putting the Prius into use, so that should be an excellent indicator for you that high mileage is defnitely not a problem for this car. The hybrid battery is warranted for 100k miles, but will perform for many, many miles beyond that!
    I bought my 2010 Barcelona Red III from Jim White Toyota last May for 19,500. It had 5,500 miles on it. It was a dealer demo. I was willing to drive from NC for that deal! I located the car using Toyota Certified Cars online.
    Best wishes as you search for a Prius. The ride, performance and technology make it an awesome car.
  7. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hey there,
    It looks like you misunderstood the battery replacement threads. You've likely seen people asking about the 12v battery, which has to be replaced relatively infrequently like all cars on the market. This is the accessory battery that helps starting the car, etc., and is just a couple hundred.
    The main battery that would cost thousands (or less on eBay, it seems), is only a problem in the rarest of cases, and shouldn't be a cause for concern when you're looking to buy a Prius, especially as it's covered under warranty as others have said.
