Newbie Looking For Help on Spinning ICE without Firing
Discussion in 'Gen 2 Prius Technical Discussion' started by jdh2550, Nov 16, 2010.
  1. jdh2550
    jdh2550 Co-Founder, Current Motor Company
    317
    249
    Ann Arbor
    Question: How do folks spin the ICE without starting it? Is this done as a hack? (e.g. using an external relay to switch off fuel and/or spark) Or as a CAN message over the bus? (i.e. is there a CAN code for "spin engine but don't run it").
    I'm soon to become the owner of a rolling PHEV experiment - err, I mean a 2004 Prius which I shall promptly turn into said experiment. Yes, I realize it's "all been done before" but that doesn't stop folks climbing Everest, right?
    My current plan is to do a large LiFePO4 pack (60Ah * 200V = 12 kWh). I plan to develop a CAN Bridge to split the CANBUS into two separate networks so that I can inject and alter messages between the battery subsystem and the rest of the network (that's if I leave the NiMH in place - if I do a complete pack replacement then I guess I'll be doing my own Battery ECU - but that sounds like more work still!)
    I want to try and get a 70mph capable EV like the PICC25 kit but with significantly better range. I'd simply buy the Ewert's HEM - but they don't sell it separately. 64 60Ah cells should be less than $5K. I don't want to shell out an extra $8,500 for the PICC25. Besides, I'd rather do it myself.
    I've been reading up on the PSD and the MG1 RPM limits. This page is great: "Toyota Power Split Device" (forum won't let me post a link yet)
    Hence the question: What's the best way to spin the ICE without firing it?
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Gas line filter plugged or no gas? H
  3. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    Drive at speeds over 41 mph in stage 3 or stage 4 and with no engine load. It will spin the ICE, but I believe without injecting/igniting fuel. At least, I think it does that. I'm sure one of hobbit's pages (as well as John1701a) goes into this, but it might take some digging.
  4. rvndave
    rvndave New Member
    34
    Ohio
    Without oil pressure, the engine spins but will not fire. I guess you could tap into the oil pressure sending unit and brake this connection.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    At anything over 22mph when I put the shifter into "B" the ice spins and doesn't fire, it's an air brake.
