newbie needs advice
Discussion in 'Gen 2 Prius Audio and Electronics' started by cazziew, Mar 7, 2014.
  1. cazziew
    cazziew New Member
    Hi I have purchased a 2007 t4 prius, it was my only option after a disasterous first buy with all sorts of problems and I was wandering if the system can be upgraded to include the parking assist and Bluetooth? Thanks
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)There should be plenty of aftermarket Bluetooth options available. Can't imagine "parking assist" could be added, and wouldn't be worth the cost if it could.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    if you want Bluetooth, the best thing to do is replace the junk head unit with a quality aftermarket unit with blue tooth. its an easy upgrade and will sound way better than the oem junk.
    07 should already have a backup camera; the parking assist I'm familiar with requires sensors in your bumper and would be an expensive pita retrofit.
    52,393
    welcome to priuschat! anything can be done if you have the quid.;)
