Newbie question about front speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by txl146, Aug 25, 2011.
  1. txl146
    txl146 Member
    301
    NY
    I have searched and found out that non-JBL front speakers are 6x9" in size, which should provide plenty of bass provided that aftermarket amp is installed.
    Question I have is how come every posts I come across regarding speaker installation involves installation of 6.5" speakers? Also, crutchfield lists only 6.5" or smaller speakers for front door application.
    I searched, but couldn't find information.
    Thanks in advance,
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There is a much bigger selection of round speakers to choose from.
    I don't remember how much depth is available in the doors, possibly a good 6x9 is too deep to fit??
    Edit: Ths thread has some good pictures at the start
    http://priuschat.com/forums/gen-iii...oval-front-door-speaker-removal-pictures.html
    There is frequently someone opening their door panels in the forum, maybe they will measure the depth for you. That reinforcement bar in the 11th picture from the top looks like the depth limiter.
    Direct link
    https://lh6.googleusercontent.com/_9QjfnwYrc0A/TZpdcgeNKaI/AAAAAAAAAGE/jl5Xr93_NNk/s500/IMG_1124.JPG
  3. txl146
    txl146 Member
    301
    NY
    Thanks for the link. Reminds me of days when I tried to install 6.5" component speakers on my Subaru. Speakers didn't fit in the front because of window guide being on the way; I had to use thick bracket in order to make speaker clear.
    How is stock 6x9" speaker compared to aftermarket 6.5" speaker in terms of bass? I noticed OEM 6.5" speaker has considerably more low-end bass compared to Infinity speaker we replaced them with.
  4. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Likely because that is what comes with most component sets. With Crutchfield you will notice most 6x9's or coax or triax. My "guess" is that 6x9s are cheaters to get lower bass cheaper, but at the cost of quality. A round speaker is better. The base Prius speakers are junk and thier JBLs are not much better.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Frodoz beat me to it. The stock 6x9 speakers are complete crap compared to 2 for $50 6.5 diameter speakers. The stock ones have weak muddy bass.
    I did a qualitative comparison here during my step by step door speaker upgrade. It's not scientific but the differences were obvious.
    http://priuschat.com/forums/gen-iii...ics/93817-gen-3-non-jbl-spearker-upgrade.html
  6. txl146
    txl146 Member
    301
    NY
    Thanks for the great information. How did speaker sound without aluminum ring attached? did you have to cut some plastic trim from the door card to make it fit?
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I didn't do an A-B comparison with and without the ring. It seemd like a case it might help and couldn't hurt. The pictures don't make it obvious but the ring was bridging a relatively small gap, under an inch and the aluminum was bonded to the speaker adapters with RTV and had a ring of rubber weatherstrip to seal it to the door card. So no thin aluminum resonance problems
    I don't remember trimming the door card. The stock speaker had been sealed to the door card with some thin foam rubber so the inside surface of the door card was relatively flat. If I did trim it it was just some trivial plastic flashing or rib.
  8. txl146
    txl146 Member
    301
    NY
    Thanks again for the useful information. We are picking up the Prius 2 tomorrow. Look forward to working on the car!
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    And suggestions to replace my JBL set?
  10. txl146
    txl146 Member
    301
    NY
    I assume JBL front speaker is also 6x9"? if so, is it considered a decent upgrade for non-JBL Prius if I can get find a set for under $50?
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    IIRC, the JBL door speakers are a different impedance and not very good speakers.
    If you do use 6x9 speakers be aware that the non-JBL Prius speakers have a considerable stand off built in to them so you would need a thick adapter to mount them at the same distance from the door as the originals
  12. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I fing the JBL speakers in my Prius to be perfectly adequate. I often turn the bass down because it is too hoonish. But I do enjoy In a Gadda da Vida at full abss occasionally. It seems to me US Prius are less well accessoried than Aussie Prius??
