Newbie Question: EV & HV Modes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PixelRogue, Jan 9, 2016.
Tags:
  1. PixelRogue
    465
    86
    US
    Hello everyone,
    Read the FAQs and related threads but still missing something between the EV and HV modes.
    In our 2010 Prius, so long as the battery has been receiving enough charge (ie regenerative breaking), car can go into "golf-cart mode" (as termed in the FAQ). Great feature and used often.
    Now have a 2012 PiP. Plug it in for a full charge, all well and fine. Now - when the EV (plugged-in charge) portion depletes, appears there is no way to engage the golf-cart mode even with adequate or ample regeneration...and battery indicates full.
    Yes, expecting the same functionality of how the golf-cart mode works from the 2010, once the plugin portion is gone. What are we doing wrong or how can this be addressed?
  2. markabele
    5,084
    1,782
    Nebraska
    You are correct. Once the EV range portion is gone and you are entirely in HV mode there is no way to get back into EV (or golf cart mode similar to the reg Gen3) until you charge the car again.
  3. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    Car can recharge while going downhill, braking, etc, and then EV mode can re-engage, I'm pretty sure.
    51,144
    congrats on your pip!
    mark and barbara are correct, but you need a pretty good hill, depending on how long you've been out of ev mode.
  5. PixelRogue
    465
    86
    US
    Huge disappointment. Want this functionality enough where I'd be open to modification. Use the golf-cart mode all the time.
    Yes, read a few posts saying they got the HV mode back. I've gotten pretty good with the HV on the 2010, and have many efforts to get the HV re-engaged with no success.
    And while the charging cable is portable, no where to really plug in. Plug in stations cost much more than gas (even when price of gas was higher.) Can't expect to plug in to you friends place or your sister and what not.
    So when on the road, it seems beauty impossible to electric only
  6. bisco
    51,144
    maybe someone will chime in with better data. i don't know if the pip is different. whenever you keep the hsi bar to the left of eco, the engine stays off until the battery gets too low, yes?
    (i never had a non pip gen3.)
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Its not how long (time) you have been out of the EV mode its the battery level when you start the downhill charging. It kind of seems like it "sticks" in the HV mode because when it goes back to EV it shows about 1.2 EV miles available rather than the 0.1 you might expect.
  8. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    The PiP behaves like a gen 3 after EV mode is depleted and will go into golf cart EV if there are 4 or more bars on battery display and engine is all warmed up. The battery indicator even changes from a more solid to 8 segments like the gen 3 indicator after EV miles are gone. So on the PiP in HV mode (after EV miles depleted and engine warmed up) can glide in EV mode up to 62 MPH (or is it 46 MPG gen 3 limit) as long as you pick your glide to be on level or downhill.
    #8 Chazz8, Jan 10, 2016
  9. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    You should look at it this way:
    If you had just a regular prius, then you wouldn't have access to 11 miles of "golf cart" action.
    So now that you have a PiP, you are starting out with 11 miles of golf cart action, something that wasn't available with a reg prius.
    So switch between HV and EV to your heart's content.
    iPhone ?
  10. 3PriusMike
    3,092
    2,413
    Silicon Valley
    If you want to use the golf cart mode, say later in the day or the next day and you are currently draining down the battery...then simply switch to HV BEFORE the miles remaining get to 0.0...perhaps at 1.0 miles. Then later when you start the car cold you will be using that 1.0 mile. If you want to drive much further, be sure to manually switch into HV right away.
    Mike
  11. CaliforniaBear
    1,179
    289
    Northern California
    Saving EV miles can be very useful. However, switching to HV at 1 EV mile left may not be a good idea. Depending on the demand, when switching to HV there is significant drain on the EV battery while the ICE warms up. That's not a problem if you have a few miles to go since the battery will be recharged to the original level, However if the distance is short you might lose most/all of your saved 1.0 mile. Switching with 2 miles or more of EV left may be more useful.
    "Golf Cart" ?? Who ever heard of a golf cart will go 62 mph up hill for several miles.
  12. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Or faster in N. There are some pretty beefy golf carts out there though, so YMMV.
