newbie question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Coreyart, Apr 6, 2018.
  1. Coreyart
    Coreyart Junior Member
    Washington State
    2013 Prius Plug-in
    Hypotheticaly, if I never plugged in my car would it still funtion as a regular Prius would?
    Or, put another way, if the larger battery completely dies, will the car still work?
    Not having any problems, I just always wondered...
  2. hill
    8,936
    Welcome!
    Part one - yes
    Part two - no
    But if almost /nearly dead / mortally wounded (versus 'completely' dead) , it'll still run. Once it gets really bad it'll most likely throw a code & then you can get a 'no cost' replacement pack, at least while under warranty.
    #2 hill, Apr 6, 2018
    j12piprius and The Electric Me like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What he said.
    Two entirely different questions.
    52,408
    no need to plug in, or worry about the hybrid battery, haven't had any issues yet, and you still have warranty left.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Lots and lots of misconceptions about the Plug in Prius, but you're close. Here's another way to say pretty much what the others said.
    You have one dinky little 12V battery to run the computers. That's the small one. If it dies, your car won't go because the computers won't run.
    You have one gigando 4.4 kWh battery to run the electric motors. That's the big one If it dies, your car won't go.
    If you don't plug in that 4.4 kWh battery, you'll just be using the bottom portion of its possible state of charge and it will run just like a regular Prius, enabling you to take trips longer than 10-12 miles.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yes, it's a fully functioning Hybrid...Toyota actually had commercials that touted the "option" of plugging it in or not. It will function as a "regular" Prius if you do not plug it in.
    No, it's a Hybrid, designed to work in Synergy with the ICE, The Battery, and Electric Motors. If the Hybrid Battery dies, it will not switch over to being a fully functioning ICE vehicle.
