Newbie w/fueling question
Discussion in 'Gen 2 Prius Main Forum' started by Vic Doucette, May 23, 2007.
  1. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    I've learned a whole bunch since finding this forum, but I couldn't find this discussed elsewhere -- forgive me if it's been covered before.
    I picked up my new Prius May 12, complete with a full tank of gas. Last night, after putting just over 500 miles on the new car -- with the onboard display telling me I had averaged a bit over 49 mpg -- I decided to fill 'er up.
    The gas station where I would normally do this is closed for remodeling, so I went to another station selling the same brand a couple miles away.
    When I started to fill the tank, the pump almost immediately clicked off. It continued to do so whenever I tried to put gas in at more than a trickle.
    After taking an inordinately long time to fill up, it finally gave me a bit of an external backsplash after 10.5 gallons.
    Is this a typical problem for the Prius, or was it a malfunctioning pump?
  2. c4
    c4 Active Member
    607
    51
    I think it's the overall design of the fuel tank.. The tank contains a bladder inside to control evaporative emissions, but this bladder changes size with temperature and stretches, so the Toyota engineers probably thought they were being clever by putting a tight sealing gasket around the filler.. By sealing in the gas pressure when you start filling, this is *supposed* to help re-inflate the bladder in the tank to maximize its capacity while also reducing the emissions as you fill, but in my experience, a large majority of filling nozzles are quite sensitive to the back pressure created in the tank; it's this back pressure that also results in the splash-back...
    I got an X-acto knife and carefully sliced out the gasket and now I never have problems with premature shutoff and never any splashback.. This seems to reduce the variation in fill-up volume for me as well: I drive until the last pip starts to flash and on my car, this means I need 33-35L, and this is quite consistent both summer and winter.. Does that mean that I actually have another 10L in the tank when the last pip starts flashing? Who knows, I've never pushed it very far after the fuel warning, so I can't say.. Perhaps by removing the gasket, I'm not maximizing the capacity of the tank, but on the other hand, if I recall, the most I've ever put in the tank was about 40-41L and that was because I was on the outskirts of the city and couldn't find a Shell station, never mind a "name brand" station to fill up at- I don't trust those independent stations..
  3. priussoris
    priussoris New Member
    1,005
    mine was very slow filling at first, it took about 5 tanks now I can pump it in normally. I think it is the bladder in the tank that is shrinking. mI too use Shell and have found I get more mpg from it and here it cost less.
    I think in due time your filling problem will be a thing of the past also dont force more gas into it after it shuts off, I have read here that it can damage the fuel cannister in the system.
  4. airliner53
    airliner53 Junior Member
    17
    Hi Vic,
    I have had my 07 Prius since December, and a couple of tanks ago I had EXACTLY the same experience you describe.
    Many on here will tell you that they have never had the problem, and some will insinuate that YOU are doing something wrong because THEY never had that happen. At any rate, it does happen and there seems to be no certain explanation. The most logical sounding explanation I have seen is that the pump nozzle is oversensitive, either due to wear or defect or whatever.
    I believe that's true, but I also believe that the design of the Prius tank, with its tight seal around the nozzle while fueling, contributes to the poblem and may cause this issue with a nozzle that may work fine on another vehicle.
    At any rate, it's a real issue but you will see it rarely. I have had it occur just once out of my 10 or so fill-ups.
    airliner
  5. clintbhs02
    clintbhs02 New Member
    32
    Ive never been able to get it to the Full mark, at half a tank I fill it up and it still hasnt been able to go back to the F mark, but its new so i figured maybe the tank is doing its job in the heat we have
    My dealer did tell me to pump gas at night, since it wont evaporate gas out of the tank anyway
  6. Enoyls
    Enoyls New Member
    48
    In addition to the bladder I'd also say it could be the over-sensitive gas pumps or just the angle/opening in general. The vehicle I traded (04 Tundra) had problems with the pump clicking off unless you held the handle at just the right angle and flow rate but only at certain gas stations. I even noticed that it was certain pumps at some stations and not others.
    With my Tundra it was a combination of factors. I've not seen the problem with my Prius but I've only filled it up once so far. We'll see how it goes next tank full :)
  7. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    I think in our first couple months with the car we had this sort of thing happen about four times, so maybe it is a new gas bladder issue. But I haven't had any trouble with this now since about January (and I find filling the tank faster, as it usually only takes 8.5-10.5 gallons).
  8. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Vic Doucette @ May 23 2007, 02:59 AM) [snapback]447991[/snapback]</div>
    Well. About 10.5 gallons is the most I've ever gotten in my car. But I still suspect a malfunctioning pump. I've never had a backsplash. After the first time it shuts off, I can usually get another half to three-fourths of a gallon in before I stop. That is with repeat click offs, but I only pull gently on the lever after the first click off.
    Dave M.
  9. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    I haven't had a slow pumping experience in my 07 but once it didn't reach the full mark.
    Many here refuel at Shell because the gas seems to be giving us better mpg. Good luck
  10. formerVWdriver
    formerVWdriver New Member
    258
    While we're on this subject, I've heard references on this site to people having their gas tank spit at them. What's that all about, and how do you avoid it?
    And, on the OP, I think the individual gas pump nozzle is the culprit. Some work fine. Some don't.
  11. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I always fill mine on the fast automatic setting, usually Costco, or Shell. Never had a problem filling it in almost a year and a half, 35,000 miles, filling twice a week. The most I ever put in is about 8 gals, when it clicks off, I stop.
  12. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(formerVWdriver @ May 23 2007, 02:18 PM) [snapback]448409[/snapback]</div>
    The car spits when more gas is pumped (or forced) into the bladder than it can hold. When the nozzle is removed the excess comes back up. My advice is to fill slowly to give trapped air a chance to escape and to stand by the tank. If you hear gurgling the pump's sensor is not going to shut off the pump when it should so stop the pump yourself. Everyone sooner or later will find a bad pump.
  13. onerpm
    onerpm New Member
    477
    MN
    All of the above responses are wrong. The Prius just doesn't WANT the gas.
    rpm
  14. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    <div class='quotetop'>QUOTE(onerpm @ May 24 2007, 10:06 AM) [snapback]449003[/snapback]</div>
    If it didn't want the gas it would be an EV only car :)
    In all seriousness I had this happen to me on my second fill, I'm thinking its a combination of the desgin of the tank and the pump your using. In other words its frustrating when it happens but appears to be a normal condition.
    On another note I wish we had Shell gas stations out here in the east from all the positive things I hear about their gas...
