Newbie - where to start?
Discussion in 'Gen 2 Prius Main Forum' started by bruce_h, Jan 1, 2023.
  1. bruce_h
    bruce_h New Member
    austin
    Hi everyone, I just joined. I've had this 2005 Prius for 4yrs now. It's been a great car. I've replaced the batteries and some other components thru a mechanic. Now I feel like I need to take a more hands on approach. What can you recommend as far as tools to get? And online training and knowledge? Thank you.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,243
    5,940
    Columbia, SC
    Step one is a cheap laptop and Techstream.
    vvillovv likes this.
  3. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
    Prius links
    PriusDIY.com: The Toyota Prius DIY Resource
    Spring maintenance
    Note: Gen 3 - 2010-15 Maintenance Videos Some General Similarities
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Techstream OBDii Scanner
    OBD2 SCANNER FOR AUTO REPAIR | PriusChat
    Gen2 OBD2 app review | PriusChat
    #3 alftoy, Jan 2, 2023
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    Youtube- WeberAuto with Prof. John Kelly.
    Get a copy of the factory service manual. There are pdf versions out on the web.
    A decent digital multimeter. I prefer anything made by Fluke.
  5. highmilesgarage
    highmilesgarage Active Member
    278
    104
    Kansas City
    start with the basics, the Prius doesn't require a lot of maintenance on your end.
    - start with oil changes, oil filters are cheap in the dealership, buy oil in Walmart. You won't save a lot from doing these but will get you familiar with the car.
    - coolant change on both engine and inverter, this will require more research since doing it correctly is critical. You can replace the inverter coolant using a vacuum tool if no bidirectional or techstream is not available. The engine coolant is also easy to do, a vacuum tool can be used or just do it manually.
    - transmission fluid change, also easy to do.
    - brake pad replacement.
    Go to your nearest Harbor Freight store, you can find a lot of cheap hand tools. Prius uses metric tools, so a metric socket set will do. A techstream software is nice to have to scan for codes if you encounter any but an Autel MaxAP dongle (OBD2 scanner) can almost do the same job for cheap and ease of use.
    Tons of DIY on youtube too.
