Newbie with dashboard lights on
Discussion in 'Gen 2 Prius Main Forum' started by AlexandraP123, May 17, 2017.
  1. AlexandraP123
    AlexandraP123 New Member
    Supply NC
    I have a 2006 with almost 160,000 miles. Have owned it a little over a year. No problems whatsoever until today - all dashboard lights lit up. First the tire pressure light- it has almost always been on and was on when I bought it. Then the triangle, and other lights started coming on and the air warmed up. Ultimately the vsc light came on. I guess just take to the dealer? I turned on and off x 5 and the lights all stayed on.
  2. Moving Right Along
    Moving Right Along Senior Member
    700
    546
    It's possible your 12v battery is going bad. From what I've heard, that can cause a lot of lights to come on.
    51,154
    welcome!
    if you can't do anything yourself, dealer is your best bet. all the best!(y)
  4. stevejenks
    stevejenks New Member
    kekaha hi
    yes take it to the dealer mine here only cost 120 dollars for a diagnoses , i had to have my hybrid battery rebuilt its a 04 with only 84759 miles on it , but two of the cells arched on mine ,,
