News on battery rubber vent smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Battery driven, May 29, 2015.
  1. Battery driven
    Battery driven Junior Member
    UK
    The well known ammonia smell is one of the couple problems with our Gen 2 Prius.
    Prius battery exploration
    I've read the forum and few other blogs regarding this issue, however no one has come back with confirmed or rather tested solution. The smell is nasty and when hot gets worse. Whole interior is soaked with the smell and so the clothing. Sometimes is so unbearable that we need to drive with open windows.
    Before buying those expensive rubber tubes, I need to know if they'll solve the issue permanently or it is just a temporary fix.
  2. JC91006
    16,482
    8,400
    this is the first I've heard of this. What rubber tubes? I guess having rubber in the car is like putting a tire in your car while it's 100 degrees out.
  3. Battery driven
    UK
    I've added a link in the original post which explains and locate the tubes...
  4. JC91006
    16,482
    8,400
    This must be a UK problem
  5. bisco
    49,492
    no, a number of u.s. owners have reported it here.pretty sure replacing them solves the problem, but i don't recall anyone describing the smell as bad as you have.
    #5 bisco, May 29, 2015
  6. Patrick Wong
    18,200
    6,474
    Is it possible there is a dead rat in the OP's passenger cabin? :cool:
  7. JC91006
    16,482
    8,400
    decomposing smell.......yeah, that'll be unbearable.
  8. bisco
    49,492
    that's why i use traps instead of poison.;)
  9. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I don't recall anything about ammonia smell, maybe a rare post on HV batt odor.
    Ammonia can cause stress cracking of brass parts (if any brass around) so that would not be a good thing.
  10. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    ...some good threads there.
    Sounds like a small but significant number of Gen2 Prii have had this issue.
    Sorry you have the problem...
  11. GMAccord
    GMAccord Junior Member
    The smell is real! It is especially noticeable if you switch between driving a prius and a non-prius. I had to switch between my prius and my honda (my honda has a towing attached which I need sometimes). Once you start driving prius you get sort of used to it and is not noticable anymore.
  12. Battery driven
    UK
    This! Exactly.
    I left a jacket in the car over night. Took it out next day and I couldn't believe how badly it stunk.
    There are days where you just get used, there are others when it can be unbearable.
    The most what worries me is the health aspect. Is this just unharmful odor or are there serious concerns.
    Toyota service doesn't want to know about it and claims it only affected gen l.
  13. Mendel Leisk
    38,727
    Sounds bad. Maybe they (quietly) changed the rubber spec for 3rd gen? I've noticed nothing.
  14. bisco
    49,492
    could it be carcinogenic?
  15. Patrick Wong
    18,200
    6,474
    I recommend you check the cabin air filter before you go to the trouble of opening up the traction battery case to replace the rubber vent hoses. My 2004 has 196K miles and there are no noticeable odors.
  16. Battery driven
    UK
    I really hope it's not.
    Cabin filter is replaced every year. It's a minor cost and easy job. No rodents rats etc...and the smell would be very different. Air con evaporator has been cleaned with the spray kit. Hasn't made any difference just masked the smell. I need to solve this and another issue which will soon discuss it in a new thread.
    #17 Battery driven, May 31, 2015
  17. JC91006
    16,482
    8,400
    I actually think this is something that's caused by water collecting by the rear battery. There have been many people that have issues with water collecting there.
    Pyho likes this.
  18. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    We have no smell whatsoever.
    If we knew the type of plastic we could perhaps look up decomposition products and causes.
  19. bisco
    49,492
    since hobbit says the smell went away without the tubes, can we assume that that is the solution? how much do these tubes cost?
    Battery driven and Mendel Leisk like this.
