Nexen CP671 P195/65/15 tires any good 2012 prius
Discussion in 'Gen 3 Prius Fuel Economy' started by anixon92, Jan 19, 2014.
  1. anixon92
    anixon92 Junior Member
    30
    hello
    I just got a 2012 prius 3. and was wordering if the Nexen CP671 P195/65/15 tires are ok on the prius for everyday driving to and from work. total of 30 miles to work.
    the reason I ask is I know a garage who is blowing these out at $125. for 2.
  2. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    never heard of them. Most people on the forum stick to Bridgestone or Michelin. I recommend a good LRR tire. Check tirerack.com and other posts on this forum.
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Nexen is a Chinese manufacturer if I'm not mistaken. That's why they're cheap. I had a pair of them on my Camry as replacements when I had a blow out and rim damage after running over some debris on the freeway. Ran them for 30k miles with no problems. In fact, they were quieter than the oe Bridgestone tires they replaced.
    Don't know if the ones you are thinking about are LRR tires or not, but they should be for consideration for mounting on the Prius.
    SCH-I535
  4. stimr2
    stimr2 Junior Member
    Columbia, SC
    Nexen is a South Korean tire company like Kumho and Hankook. Hyundai and KIA use them as a OE tire. The CP671 aren't LRR tires. Nexen labels them as a performance all season tire. They're the OE tire on the KIA Optima and Hyundai Veloster
    Nexus 7 ?
    retired4999 and xliderider like this.
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Checking the Nexen CP671 tyre on the UK RR figures required by law within the EU the tyre rates depending on size an E to C rating on a scale of A to G. A being the best, it also rates C for wet grip, but it's noise rating is very poor at 75db. The best tyres rate at 67/68 db and tyres with ratings above 72db (not including specialist tyres) are to be excluded from sale in the near future.
    John (Britprius)
  6. anixon92
    30
    ok thanks
