Next Gen PiP2 Mystery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wjtracy, Dec 20, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    49,490
    i haven't seen it, thanks! not much there but the same old questions. interesting how they say it hit the low water mark, but is 3rd overall in the world.
    #2 bisco, Dec 20, 2015
  3. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    As I've said, to get me to buy a newer PIP, it would have to get about 20 EV miles on hills/high-speed roads, and allow me to go 70 without the ICE starting.
  4. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    I was hoping the PiP2 would be a little bigger car. and not biggger batt just shoe-horned into the Gen4,
  5. Tideland Prius
    16,155
    Considering that the Gen 4 has a 70mph cut off limit, I wouldn't think the PiP would be any less (although the one caveat is that the engineer in that Nikkei articles said that they're using a different electric motor and different Li-Ion battery than the 4G Prius)
  6. bisco
    49,490
    why?
    20 miles at 70 mph ain't gonna happen, not even on flat roads.
    #6 bisco, Dec 21, 2015
  7. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    In other words build the car around the PiP concept, much the same way as Gen2 was built around the hybrid concept. Maybe they need a little different shape to optimize the cargo space/battery space.
    I am thinking we get 20-25 miles do not know about the 70 MPH. I am hoping the induction charger is included and I hope that works well.
  8. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    If the gen 4 goes 70 MPH on electric, then the PiP certainly will. I think that's a reasonable cutoff speed, and was thinking even 65 MPH would be nice. I rarely go much above 70 on Oregon's slow freeways. Above that you want to be burning fuel considering how quickly you will go through kWh.
    The PiP should be the same platform as the liftback, otherwise it would be designated as a separate car model. Lack of a spare tire should be the only compromise, with a rear deck that is level when the rear seats are folded flat. I would guess 18-20 mile range, which I find to be the sweet spot for this vehicle. If more range is needed on a regular basis, the Volt is a better option.
    I'm not a fan of wireless charging due to the reduced charging efficiency, but I do see how it could benefit some people who cannot easily access a charging cable. It should be an option rather than standard feature since so few would actually use it, and the expense is non-trivial.
    #8 Redpoint5, Dec 22, 2015
  9. bisco
    49,490
    are we talking epa miles, and will it test the same as the current pip? i'm still confused as to epa testing.
    i believe the gen IV was built with the pip in mind, but it was not likely a priority, as toyota doesn't see it as a viable product to compete with lift back numbers. i'm just happy they haven't dropped it altogether.
  10. Redpoint5
    1,026
    508
    Portland, OR
    When I give a range estimate, it is according to EPA certified ratings. I expect many on here will get better than 20 miles on a charge, as I already get 15 in the summer.
    The EPA rates the PiP to something silly like 3 miles of range before the gas engine starts because their standardized testing method requires hard enough acceleration at the 3 mile point. Pressing the throttle to far activates the gas engine. PiP v2 will either need a higher threshold of power until the gas engine kicks on, or a true EV mode that locks out the gas engine no matter how hard the skinny pedal is pressed.
    I too am pleased to see Toyota committing to the next iteration of the PiP despite the fact that it doesn't generate revenue for them. It will be a stepping stone for them to create extended range EVs and eventually a dedicated EV.
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I can get 10 miles at 60 mph. All they have to do is double the battery pack plus a bit more, say 10kWh. You don't think that's going to happen? Yeah me neither, that's why I don't think I will be purchasing PiP2.
  12. bisco
    49,490
    i suspect the drain from 60-70 mph is more than incremental, but i could be wrong.
    i am expecting a 50% increase in epa range, from 11 to 16.5, but possibly more. 20 tops.
  13. bisco
    49,490
    epa is 11. there is something in the fine print about the engine coming on at 6, but i don't know if toyota is concerned with that or not. they may feel the ice is needed in certain power situation, but with a larger battery and more powerful motor, they may not.
  14. markabele
    5,084
    1,782
    Nebraska
    Forgive me, I've done almost no research on the Gen4 yet....
    So in the new Gen4 that will come out you will be able to pulse and glide all the way up to 70 mph?
  15. Redpoint5
    1,026
    508
    Portland, OR
    Tideland- What is your source for the 70 MPH limit in EV mode?
    Toyota literature says the EV powertrain is 20% more efficient, which means the battery doesn't have to grow in size as much to achieve greater range.
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Toyota was (and arguably still is) the leader in hybrids, now it is late to the party with PHEVs and BEVs.
    If Toyota made a PiP that was specially designed with 25kWh to 30kWh of battery and a few gallons of petrol (ala BMW i3-REX) but with Toyota reliability and Prius comfort, technology and PSD for when you are in hybrid mode instead of EV only it would be a killer. It would not be a competitor to the "normal" Prius, it would be a different class. An EV with an engine, not an ICE vehicle with a battery. I expect it would cost about $50K retail in the lower volumes so maybe the Lexus brand would need to be slapped on it.
    100 real world mid-speed highway miles plus an engine at 50mpg and 4+ gallons gets you the magic "300" number that everyone wants for no particular reason. 99% of the driving would be done on EV only. The engine and petrol would be carried around for emergencies and "peace of mind".
    And just in case I will mention I own multiple Toyota/Lexus hybrids (multiple Prii), and a Leaf as well as a subset of our collection.
  17. bisco
    49,490
    and it would sell a pittance, like all the other cars in this class. they're not interested.
  18. bisco
    49,490
    this is the next gen pip thread people, let's keep it on point!
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Hybrids also didn't sell well until Toyota changed the game. That's the point. Why are they now following where sales already are (and aren't) versus making a new market like they did with the Prius. Everything is a "Prius-killer" because they invented the market. Tesla has taken the top end BEV category and things have to be "Tesla-killers" now. Nobody has a good PHEV yet even though a few have tried.
  20. bisco
    49,490
    probably for the reason you stated. too expensive, would need lexus badge, wouldn't sell many.
