Featured Next-gen spoked magnet design spins up cheaper, lighter, more powerful electric motor
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Trollbait, Nov 21, 2018.
  1. Trollbait
    11,517
    tl;dr
    When magnets get hot, the performance of an electric motor drops, and current motor design used in cars makes directly cooling them hard to impossible. So you need more expensive magnets that can handle the heat, or use a bigger, heavier motor for a given power output.
    The spoke arrangement of magnets(above, black the magnets) makes direct cooling of the magnets possible. The arrangement also means less magnet material is is needed for the same output; 25% less.
    Not a new concept, but this company, Equipmake, has a cheaper way of making them. Their motors will appear in the Ariel Hipercar and an electric bus, both planned for 2020.
  2. hill
    8,159
    I hope these suckers aren't like so many touting vapor-ware / cheap no loss /charge in 5 minutes / 400 mile battery tech, or 95% efficient PV solar.
  3. Trollbait
    11,517
    They are already going into two vehicles.
    GE and others knew about the advantages of this spoke design. It was just easier to come up with a way to make the standard design cheaper. The article is worth the read.
  4. PriusCamper
    PriusCamper Senior Member
    11,070
    4,506
    Pacific Northwest, USA
    If they were able to make the magnets in a tear drop shaped they could boost performance even more, increase cooling, and decrease amount of material used. Of course durability, as well as cost of tear drop shaped magnets is prohibitive, at least for the moment.
  5. bwilson4web
    15,513
    The article is a little light on technical details:
    • Magnetic flux lines and intensity
    • Mechanical stress a there is no description of stress on the relatively low stress magnets
    It takes more technical details than an advocacy articles to pique my curiosity.
  6. Leadfoot J. McCoalroller
    7,140
    6,687
    Pennsylvania
    2018 Prius c
    Teardrop Magnets is the name of my electro-rhumba joy division tribute band
    hill likes this.
  7. bwilson4web
    15,513
    Perhaps 'sweeter than all the roses. Covered all over from head to foot with sweet violets."
  8. PriusCamper
    11,070
    4,506
    Yes, I've learned the hard way that paisley really is a form of advanced technology...
  9. El Dobro
    El Dobro A Member
    6,978
    3,213
