Next-generation C-Class to go completely hybrid
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Mar 24, 2011.
  1. Tideland Prius
    16,153
    Mercedes insiders have revealed that the next generation C-Class will have a hybrid setup on every model.
    The move is intended to drive down consumption and emission figures to class-leading lows.
    New friction reduction and weight saving technology is also being developed, and Mercedes engineers are currently considering whether three-cylinder engines could be used in the family saloon and estate range.
    Mercedes has apparently set strict emissions targets for the new cars, and is aiming for the diesel-engined cars in the range to have an average of 100 g/km CO2 emissions.
    The current C-Class has just been facelifted, but the next-generation car is due in 2013.
    Source: Fifth Gear
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Brits and their "news"
  3. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    Hybrid or just a "start-stop" feature?
  4. green4u
    green4u New Member
    115
    CA
    Great! But why limit it to the C class? By limiting a hybrid powertrain to Mercedes' entry level junk, people will continue to only look down on it (hybrids AND the C class).
  5. spwolf
    3,156
    440
    Eastern Europe
    start stop has a new name... "micro-hybrid"!
  6. bisco
    49,467
    does merc have a hybrid available yet?
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    they haven't limited it to the C class. several months back, it was reported that the S class will turn into hybrids.
  9. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    One way or another, in 2016 when the EPA mandate of 35mpg CAFE comes into effect and Mercedes still has large cars on the road, the smaller C-class will have to get stellar gas mileage for Mercedes to meet the requirement.
    Question: Does anyone know how diesel is treated in the new CAFE requirement? Does diesel have to meet a higher requirement, or can an automaker put V8 diesel in every car that gets 35mpg but still destroys the environment?
  10. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    You think its junk?? *cries in a corner*
    Reasons I believe it is an intelligent move: They probably sell more C-classes than any other model. They probably also want to test out how it will fare before moving on to other models. They probably want to allow those who spend money for more expensive models keep their performance oriented gas engines (even if its just perception).
    I dont necessarily think they are "limiting" hybrids to the C-class. The OP just said their wont be a standalone gasoline engine C-class.
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Isn't that hilarious?
  12. hill
    8,177
    Mercedes corporate average fuel econome (CAFE) has been in the toilet so long ... I was beginning to think they felt it was a status symbol. "We don't NEED no fuel economy". As though they were proud of paying more, vis a vis CAFE penalties. Hybrid offerings might insult Mercedes owners, and their way of life.
    :p
  13. telmo744
    2,178
    768
    Portugal
    Citroën has adopted that "reference", also.
    I find it unnaceptable, instead. Only ICE propels the vehicle. It's a marketing abuse.
  14. Skoorbmax
    2,641
    264
    Western NY
    Agree.
    I've noticed every car ad now touts the "fuel efficient <insert car name>". Doesn't matter if it's a huge truck or whatevs, but calling cars that stop when idling a "micro-hybrid" isn't just greasy it's an outright lie. It's like calling somebody micro-pregnant. You are or you're not.
  15. spwolf
    3,156
    440
    Eastern Europe
    i am assuming thats how they will be "hybridizing" their whole fleet.
  16. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I can manually start/stop my conventional vehicle right now.
    In theory, if I kill the ignition to the engine during slow-downs, it will still spin the alternator and charge the battery. Regen anyone?
    That doesn't make it a hybrid.
  17. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    That does not cut it. The battery and starter are not up to the task. The electronics are trivial so those doing these auto stop start are adding beefier starters and advanced lead acid batteries. If they do it fleet wide as ford is doing the incremental cost is not very large. It does make replacement batteries more expensive.
    Mercedes is using a small lithium battery and a flywheel motor, similar to the honda ima system. It is likely they are adding a second clutch like hyundai and may be removing the torque converter. This can improve combined fuel economy about 20%. By using an electronic airconditioning more fuel is saved, and it provides a luxury feature.
  18. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Right ... my point was it has to provide some motive force from a secondary power source to be a hybrid.
    My post was in response to Skoorb ... i should have quoted it:
