Next generation Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Sep 7, 2017.
  1. bwilson4web
    15,524
    Just idle speculations:
    • 20 kWh usable - next generation battery to provide city and surrounding town range. So this morning I drove from Huntsville to Decatur for breakfast and back home for $0.60 electricity, $0.50 parking meter and $0.10 home charging.
    • 1.2-1.3L engine (or smaller) - tweak it for 42% efficiency and control laws that allow it to ONLY run at peak. Support electrical pre-heating of catalytic converter, engine and transmission oil.
    • 450-500 mi (720-800 km) - total gas range as humans need a biology break too.
    • 3000 lbs (1365 kg) - maximum empty weight.
    • 4.5 seats - the rear center console supports a baby seat, 70 lbs (32 kg)
    • 4-wheel camber and toe alignment (I mean really!)
    • rear seat fold down and easy removal
    • 1,000-1,500 lbs tow (455-680 kg) rating
    • CCS fast DC charging, 50-75 kW rate
    • raise it 2" (5 cm)
    • optional: dynamic front and side air dams that work only above 45 mph (70 km/h)
    • optional: self-driving above 45 mph (70 km/h)
    #1 bwilson4web, Sep 7, 2017
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. Pijoto
    Pijoto Active Member
    199
    151
    Dallas, TX
    Personally, I'd like to see a flat and flush cargo area when the rear seats are folded down, like the regular Prius. Most likely have to give up the 20 KW battery, or give us the option of having a smaller 10 KW battery (hopefully batteries will shrink enough) to provide a flat cargo area. I like sleeping in the back of my Prius for camping trips.
  4. offib
    offib Member
    162
    94
    Dublin
    Four Touring
    Never mind just the tow, what about carrying capacity? 450kg minimum would be appreciated. That and a trunk floor that's as flat and identical to the standard Prius.
    Anyways, here's hoping anyone inside Toyota is reading this thread. I am right in saying that they've looked around here before as pointers from the products' owners, right?
    And maybe a front bench seat, or at least a most imperceptible division between the front seats?
  5. bisco
    49,507
    get the battery under the hatch floor, instead of on top of it.
    but a better question instead of all of our personal desires:
    what would help toyota sell more. that's more important than what i want.
    offib and HPrimeAdvanced like this.
  6. jungleland1972
    73
    65
    Chesapeake Beach, MD
    Sales people that understood the car would help. My sales person knew nothing about the car. On the test drive I had to explain to her what the "B" was on the shifter. It's such a marvel of technology and engineering, if the sales staff understood it, they would be flying off the lots.
    Andyprius1, RyanSBTeach and offib like this.
  7. bisco
    49,507
    yep, and that hasn't changed since the original prius 17 years ago.:(
    pjm877 and RCO like this.
  8. Pijoto
    199
    151
    Dallas, TX
    Why bother learning about a Prius, when the majority of your job is spent churning through cookie cutter Camry's and Corolla's to customers who could care less about cars in the first place?
    Yeah, better sales people and actually advertising the Prime to a wider audience would do wonders. Until then, only Gas Prices skyrocketing will return the Prius lineup to its past glory days.
    Prius Maximus and Mark57 like this.
  9. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Video record option using that HD/4k camera in front of the rearview mirror.
    bwilson4web likes this.
  10. Sid786
    Sid786 Active Member
    262
    146
    Cherry Hill, NJ
    In Toyota Camry Hybrid 2018, battery is already under the hatch floor. So Toyota already know how to do it. It is now just a matter of time, when Prius Prime battery will be under the hatch floor. I am positive the next version of Prime, will have the battery under the hatch.
  11. bisco
    49,507
    i hope you're right, but the hycam is not a plug in.
  12. offib
    offib Member
    162
    94
    Dublin
    Four Touring
    I'm not sure about the advertising, but just having the Prius nameplate is perhaps enough exposure. From the InsideEVs sales chart, the Prime has shown that it has been kicking nice person since its debut. Most likely because it's the cheapest Prius on offer after incentives. We should note that whenever an EV or PHEV booms in sales unexpectedly, availability is often constrained by the speed of battery production. So lets not hope of a dramatic uptake so soon as that could lead to dealers really hiking up the sticker price.
  13. Michael Ge
    Michael Ge New Member
    27
    25
    "optional: self-driving above 45 mph (70 km/h)" unlikely since Toyota can't even get the Prius Prime to stay in its own lane with steering assist how can they ever get self driving to work? I have been dealing with Toyota on steering assist for months with no results. The steering assist in the Prius Prime does not function the same as it does on every other Toyota model. Toyota claims that the system works as designed. I wonder why the design doesn't carry a different name than the systems in all other Toyota models. Since it works in every other Toyota model but not in the Prius Prime. The service manager at my dealer drove a few different Prius models with steering assist and stated clearly that it doesn't function in any way similarly to the other Toyota models. This is somewhat weird as it is marketed as the exact same product with the exact same capability. If you are looking for safety you best review the Prius Prime safety suite functionality prior to purchasing as Toyota has no fix for this safety problem.
  14. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    You bought the wrong car if you wanted a car to keep in itself in its lane. Nowhere does TSSP mention that capability.
  15. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Very true, I had a supposed Tech answer a question as to why all 4 doors + trunk do not unlock from touch.
    He said Toyota did this for Security reasons, all the new cars are doing this now. It turns out after looking at the thin Owners guide, that I had changed my habit and was not holding the handle long enough ( 2 sec) . I corrected my method. This BSer hopefully will get caught someday.......
  16. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    So basically you want an i3 REx with two more cylinders and a more optimized engine, and towing capacity? You'll have to pay a lot for that. Like, a lot. (You're asking for a lot of very expensive things together in the same car, really.)
    Also note that larger cylinders work better for thermal efficiency, and IIRC the LIVC cycle that Toyota's using works best with 4 cylinders and really wants a minimum of 3 cylinders to avoid having a huge intake plenum. So, I'm guessing that the smallest displacement you get is in the 1.8-1.9 liter ballpark. (To get that 42% thermal efficiency, you might even be looking at a three-cylinder derivative of the Camry engine, or something odd like that. And, vibration wouldn't be pretty there.)
  17. Andyprius1
    2,327
    859
    Cool CA
    As you say if they really knew the car they’d sell a lot more. If the salesperson is require to buy that model in order to get the job, then an expert on every model could be produced at the Dealership. As it is now, the customers inadvertently feed info to the salesman.
  18. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Gen4 Prius in general, and the Prime even more, are gaudy. People who want a Dodge Charger will buy the Dodge Charger - the Prime tailend isn't fooling anyone. It's sort of like New Coke - make it more like the competition and less like what the current customers like. The competition isn't buying, and current customers are put off by it.
    I like all the technical dodads on the Prime, but dump the light show and bring back a rear wiper. And while you're at it, get rid of all those expensive parts mounted in the bumper. A minor bump shouldn't cause major damage.
