Next Track Button Not Working on Steering Wheel
Discussion in 'Gen 2 Prius Main Forum' started by Manuel Orellana, Mar 11, 2021.
  1. Manuel Orellana
    Manuel Orellana Junior Member
    28
    Toronto
    So this is a bizarre one....
    I have a Sony stereo installed on my Gen 2 Prius, the stereo has Apple Car Play and Android Auto, I got a box that connects to it to ensure that the steering wheel controls work which they do ..... for the most part.
    For whatever reason, the Next Track button doesn't work, every other button on the steering wheel works fine, previous track, volume up and down, mode, they all work, just not next track.
    So I ordered a replacement off Ebay, received it and asked my buddy who's a mechanic to help me install it, so went through the process, removed the airbag, removed the controls on the left, installed the new controls. Before putting everything back we tested it and everything worked, all the buttons including next track.
    Feeling confident we put everything back together, talked for a while and then I drove off. Low and behold, just noticed that the next track button doesn't work, which means my previous one was probably fine as well. It seems to have stopped working after putting back the air bag and putting everything back together?
    It's the most bizarre thing, I've tried resetting the stereo back to factory settings but no dice, same thing, all buttons work except for the next track button.
    This is driving me absolutely nuts, I wish I knew which little box I bought that hooks up to the radio so the controls work on the steering wheel I'm wondering if it's something to do with that, having said that, if that was the issue it would have failed before my buddy put everything back, but no, it failed after everything was put back together.
    Any suggestions guys? If you need any more information I can try and look it up, the stereo model I believe is a Sony XAV-AX100
    Thanks everyone
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Check pages 3820/21 and 3906/07:
    Code:
    https://drive.google.com/file/d/17LZFTHg-OdnS1QjJnR4Qc7W3jsmAB4xS/view?usp=drivesdk
    As you can see the steering pad switches switches only several resistors. So for seek+ you should read about 2.5 Ω max. (or about 0.5 V with power on) when pressed. (The connector from the manual is behind the stereo.)
    If you get other readings there's probably some contact corrosion or similar.
    If you get correct readings with a multimeter your box seems to need a calibration or worse. (My Android Stereo Head Unit has a learning function to measure the signals of the buttons and save it with a user defined functions for short and long pressing the buttons. Maybe you can do the same to recalibrate it.)
    [​IMG] [​IMG] [​IMG]
  3. Manuel Orellana
    28
    Toronto
    Thank you for your response, my only argument is that it was working, before we put the airbag back in it's place everything was tested and worked fine, car was powered on radio ran and was tested without issue, once everything went back on and it was tested afterwards it didn't work, if it was an issue such as the one you describe I figured it wouldn't work at all. My stereo also has a learning function to configure the controls, when going through it I can calibrate all other buttons except for next track, very puzzling.
    Again, thank you for your response, I will have a look at it again hopefully this weekend.
  4. Manuel Orellana
    28
    Toronto
    Hi Everyone,
    More to report on this weird issue. Today after a friend of mine gifted me enough tools to repair a spaceship I decided to take another crack at the situation.
    I put back the original controls as putting in new ones didn't seem to matter, the new one I had put in I bought on Ebay and it was actually in worst physical shape than mine so I was glad to put back the original.
    As soon as I put everything back in, I tested it and low and behold it worked again, but again, it was only temporary, shortly after it stopped working again.
    I got home and left the car parked outside for a few hours before putting it away in the underground, as I got in the car I tested the controls and they worked, however, after about a minute, they stopped working.
    @MickyMatter I believe you're on the right track although I'll have to continue to do more research, what I do know is that there's nothing wrong with the stereo and nothing wrong with the controls on the steering wheel, the problem is somewhere else, probably the little box that I had to buy to get the controls to work with the stereo. I don't remember the brand or much information about it so I'm going to have to look that up and then track the problem that way.
    If anyone else has had this issue or can provide any other input I would greatly appreciate it, so far I do believe that @MickyMatter is probably on to something.
    Thank you all for your assistance.
  5. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    ... and that somewhere else might be the spiral (a. k. a. the clockspring) cable. Does the button intermittently work when you turn the steering wheel to different positions?
    Don't buy secondhand or aftermarket, buy a new OEM one. Price compare online at Toyota Part Center Online. After all, you really do want your airbag to go off if you have a bad crash, don't you?
  6. Manuel Orellana
    28
    Toronto
    I thought about the clock spring but no it doesn’t make a difference if I turn the wheel, I have experienced clock spring issues in the past with another vehicle it was the first thing I thought of. The only consistent behaviour is that it works for a minute or two after turning on the car if it’s been off for a few hours. I have a feeling it’s it’s something to do with the box that sends the signal from the steering wheel to the stereo, but not sure yet. Will keep researching
  7. MickyMatter
    260
    168
    Germany
    Theoretical scenario: Car is off for a while. Auxiliary battery voltage drops. Car is on. Pressing next track button switches a specific resistor resulting in a specific voltage. Box learnt this voltage to interpret as next track. Inverter charges auxiliary battery. Higher battery voltage with the same resistor leads to a higher voltage after the next track button. The box isn't able to interpret this "new" voltage.
    Points against this theory:
    • The next button should be the smallest resistor of the buttons. Otherwise there would be more impact of the resistors than of the voltage.
    • When the car is on the inverter should keep the voltage stable - independent of the battery voltage.
    However:
    Do you own a fine adjustable DC voltage supply? When the button seems to fail, can you open the circuit (the wire from the buttons) near your box and first read its voltage (compare with repair manual) and second try to supply this voltage +/- a bit offset to simulate the button and to trigger the box?
    I hope I'm writing no complete bullshit, because English is a foreign language for me.
    dolj likes this.
  8. Corey bourke
    Corey bourke New Member
    New south wales
    2017 Prius+ MPV
    Hey Manuel, I’m having the exact same issue with a Sony xav ax5500. I haven’t found a solution, although I have changed my clock spring to an oem one, and have also changed the little box that you are talking about to a brand new one and still nothing. Any update?
