Nitrous vs. Regular in tires
Discussion in 'Gen 3 Prius Fuel Economy' started by Lopez92311, May 22, 2013.
  1. Lopez92311
    Lopez92311 Junior Member
    35
    High Desert SoCal
    Has anyone used nitrous in the tire as opposed to regular air? Do share...
  2. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    In an ordinary street car, nitrogen in the tires is pretty much useless snake oil. The air you breathe and use to fill your tires at the gas station is I believe 82% nitrogen.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    78% N in normal air.
  4. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    "Nitrous" = Nitrous oxide = laughing gas at the dentist office = oxygen booster when injected into an engine.
    Nitrogen = largest component of Earth atmosphere and when used at higher concentrations to fill a tire provides somewhat better resistance to leakage due to larger molecular size and more temperature / pressure stability. Checking your tire pressure regularly and adjusting it accordingly achieves the same goal.
    Some tire chains "nitronize" your tires for free. I wouldn't pay for it, though.
