no ac power
Discussion in 'Gen 2 Prius Audio and Electronics' started by rocketdoctor, Oct 4, 2008.
  1. rocketdoctor
    rocketdoctor New Member
    lafayette,ca
    the aux power plugs in my prius are no longer working. I suspect a blown fuse can someone tell me what the label of the fuse is I can;t figure it out based on the Fuse cover legend.
    thanks,
    Scott
  2. eagsc7
    eagsc7 Geocacher
    50
    Prescott, AZ
    so then you actually have no DC power coming to the port.
    If you open your owners manual, Look up Fuse Pannel and you will find the correct pannel under the Drivers Side Dashboard(by the Hood Release). I would reccomend checking most, if not all of them while you are there.
    The Steaks
  3. rocketdoctor
    lafayette,ca
    thanks alot I overlooked that fuse box
