No Auto-on Headlights in US: Mystery Solved
Discussion in 'Gen 3 Prius Main Forum' started by SPlautz, Mar 28, 2011.
Thread Status:
Not open for further replies.
  1. SPlautz
    SPlautz Junior Member
    51
    Virginia Beach VA
    I believe I figured out why the auto-on headlights were disabled in the U.S. on the Prius. It became crystal clear when the Lexus hybrid was introduced. Why would someone want to buy a pricey Lexus hybrid when the Prius gives you basically the same "luxury" features and at a higher mpg? So they had to do something, and getting rid of the auto-on lights was one of the things they did to solve the problem. I guess they couldn't get away with disabling it in Canada due to the DRL circuitry, laws, and/or dumb people not knowing whether their real lights were on or off, etc. But all U.S. Prius sedans that have a sensor on the dashboard can be wired up for auto-on lights. It requires stringing a wire from that sensor, to your ECU and another wire from the ECU to ground (you might want to put a switch here too). The ECU itself is not disabled in anyway. BTW that sensor has a three purposes that I know of. It is for adjusting your AC temperature lower if it senses direct sunlight coming into the car. That's why the AC is too cold at times.. look at the senor, is direct sunlight shining on it? The third purpose controls interior dash dimming. This was disabled when they removed the auto-on wire and should be re-enabled once autolights are restored. So all Prius drivers can thank the Lexus hybird for not having auto-on lights and having to suffer with a too dim dash during the day if their headlights are on, i.e. when it rains. Yeah I know you can dial up the dimmer, but that gets old after awhile whenever it rains, and then you get blinded it night. lol
  2. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Did the previous generation Prius have auto-on headlights (before the Lexus hybrid was introduced)? If not, your argument makes little sense.
    You can set the dimmer to day mode even when the headlights are on by rotating the dimmer upward until it clicks in place. No more too dim dash.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    No. I'm very happy the way they are. Auto-on doesn't mean auto-off in bright daylight. I had to turn the parking lights on to turn off the headlights in my Intrigue--no off switch. Another example of brilliant GM engineering.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
Thread Status:
