  1. Efmims
    Efmims New Member
    Houston, TX
    ive never posted here before but yall have been extremely helpful for me! Hopefully someone has an idea for me.
    I have a 2005 prius with a few different issues. Currently my BRAKE light is on, as well as the yellow (!) And ABS and VSC lights. I have no brake pressure, I have to put my foot to the floor to stop. (Taking it back to the dealer tomorrow)
    I had my 12volt replaced because the car wouldn't start. I have an issue where my dashboard lights wont come on (fuel gauge, MPH, etc) so I cant see what gear I'm in or how fast I'm going.
    Any ideas?
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Read the OBD2 code(s), then post them here for additional help.
    Raytheeagle likes this.
  3. johnhommrich
    johnhommrich Junior Member
    Kentucky
    It would be interesting to hear what the dealer finds. It would be nice if you could confirm the actual voltage your 12v battery is supplying to the car. Believe it or not sometimes new batteries are not fully charged when the consumer buys them. If the seller doesn't fully charge them the battery could be supplying less voltage than you would expect. The 12 v battery must be charged and in good condition or it can cause problems with our prius.
  4. prius_deep
    prius_deep Member
    105
    38
    road
    Should have taken a picture of the engine compartment so we could see; if you have any brake fluid, or how low it is.
  5. yoshihasaprius
    yoshihasaprius New Member
    kissimmee
    hello, this has happened to me!
    I get the struggle.
    you might need a new brake actuator :)
    You can easily buy the part at a salvage shop OEM or online
    to labor/replace it can cost 200 bucks
    it is located in a fairly difficult area
    good luck!
    there are youtube videos if you're up for the challenge
  6. bisco
    49,373
    how many miles on her?
    yoshihasaprius likes this.
  7. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Damn! Labor rates are crazy cheap in your area. Are you sure $200? Or did you mean $2,000! $2k would be more appropriate. There's a lot of work to get at the ABS actuator as you know.
  8. yoshihasaprius
    kissimmee
    We are looking at 177k
  9. yoshihasaprius
    kissimmee
    It’s 200!
    Yes we have mechanics EVERYWHERE here
    I had my inverter changed for just 50 bucks a while ago
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Given that there are a number of electrical plugs that are typically removed with a 12V battery replacement, it is more than possible that one or more are not correctly seated, or not plugged in at all. In some cases, the ground cable is even unbolted from the body to replace the 12v, and any looseness there can cause all sorts of problems.
