NO CRANK NO START HELP!
Discussion in 'Gen 3 Prius Technical Discussion' started by RATCHET ACPSCAN, Jan 7, 2024.
  1. RATCHET ACPSCAN
    RATCHET ACPSCAN New Member
    TEXAS
    HELLO FRIENDS IN FORUM,
    2010 hybrid prius has a no engine crank , no start , no diagnostic trouble codes to determine a failure, regular battery is new, at a point when start / stop switch is applied i see that the hybrid battery shows 4 bars but quickly deteriorates to 1 bar, and the 'READY" INDICATOR STARTS FLASHING ERRATICLY. fuses on engine compartment are ok. AT SOME POINT A COARSE STARTER NOISE AND TRYS TO START THE ENGINE BUT DIES , SO NO ENGINE START,
    WE ARE USING AUTEL SCAN TOOL
  2. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
    There should be error codes for symptoms like that. If not it's possible your new 12v battery is defective or needs a full charge.
  3. ChapmanF
    17,326
    Video of dash lights?
    RATCHET ACPSCAN likes this.
  4. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    Autel sells a wide variety of scan tools, and not all of them will be up to the task of detecting codes thrown by the hybrid system. What Autel model are you working with?
    RATCHET ACPSCAN and Brian1954 like this.
  5. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    You need to be on an alltel scanner above number 5 I think eight is out now I know a five can bleed the brakes and do most everything on a generation 2. My buddy has a red five and says now that the eights out you can buy the five six and if there was a seven for a couple hundred bucks at best with the cord these things have sold for I think 700 plus dollars but don't hold me to that because I don't look at their prices that much and I've seen some other cheaper scan tools in the 250 range now that are about eight or nine inch screens look like an iPad and have the ABS brake bleeding and everything right on the packaging and if I call the manufacturer of some of these stupid things or their tech line it says for my '09 and my 2010 it's supposed to be able to do the full brake bleed but I don't know if that means it will reset the sensor that I can't get to set right now The zero angle or whatever that thing is.
  6. RATCHET ACPSCAN
    TEXAS
    HELLO I WORK ALOT OF HOURS PER DAY I WILL GET IT TOMORROW SEE IF I CAN DOWNLOAD IT
    2018 AUTEL MAXI-ELITE UPDATED AND ACTIVE SOFTWARE THRU JUNE 2024
    #6 RATCHET ACPSCAN, Jan 9, 2024
  7. RATCHET ACPSCAN
    TEXAS
    ILL TRY MY BEST TO UP LOAD A QUICK VID AND SEED IF I CAN GET SOME CODES USING ANOTHER SCANNER FOR THIS 2010 PRIUS
  8. RATCHET ACPSCAN
    TEXAS
    IT WONT LET ME UPLOAD THE SCAN BUT HERE IS THE DTC FROM THE AUTEL ULTRA SCANNER
    P3000 BATTERY CONTROL SYSTEM CURRENT
  9. bisco
    51,141
  10. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    Please turn off your CAP LOCK, no reason to yell.
    bisco and Brian1954 like this.
  11. bisco
    51,141
    ARE YOU SURE????
  12. ChapmanF
    17,326
    you made bisco use capitals
  13. Mendel Leisk
    40,575
    anyone else here use textpad? just curious.
    ANYONE ELSE HERE USE TEXTPAD? JUST CURIOUS.
    Anyone else here use textpad? Just curious.
    aNYONE ELSE HERE USE TEXTPAD? jUST CURIOUS.
  14. bisco
    51,141
    my finger still hurts :cool:
  15. Mendel Leisk
    40,575
    Take original post into TextPad, select, invoke "sentence case":
    Hello friends in forum,
    2010 hybrid prius has a no engine crank , no start , no diagnostic trouble codes to determine a failure, regular battery is new, at a point when start / stop switch is applied I see that the hybrid battery shows 4 bars but quickly deteriorates to 1 bar, and the 'ready" indicator starts flashing erraticly. Fuses on engine compartment are ok. At some point a coarse starter noise and trys to start the engine but dies , so no engine start,
    we are using autel scan tool
    Got it decades back, used it for a few years, finally shelled out for a license.
  16. ChapmanF
    17,326
    I can do the same thing just by looking at the post.
    Have you investigated whether it can punctuate a post from Tombukt2?
    Brian1954 likes this.
  17. bisco
    51,141
    or fix biscos grammer?
  18. Mendel Leisk
    40,575
    It'll wrap text with hard returns. Indesepensable copy/pasting from pdf's. Loads of stuff; think programmers like it. Also can maintain a "workspace": you open the program, and all your text logs, missives, diaries, whatever, are open, as you left them, with any selections or whatever.
    (graphic deleted, posted in wrong thread)
    #18 Mendel Leisk, Jan 12, 2024
    Mr. F likes this.
