No dashboard lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevan808, Feb 1, 2025.
  1. Kevan808
    Kevan808 New Member
    I've seen other threads on this, but wanted to check on my particular situation. From what I've seen it usually seems to be a combination meter, but I wanted to double check.
    For a while now, my dashboard lights haven't been lighting up. Occasionally they will, but very rarely. The display with the battery efficiency turns on and will show the car icon for the electricity generated, but is not displaying any associated numbers.
    Headlights and everything else still seem to be working, but the spedometer and odometer are not shown at these times.
  2. JC91006
    16,827
    8,600
    yes it's your combination meter that's causing the issue.
  3. BiomedO1
    BiomedO1 Senior Member
    4,093
    2,140
    SacTown, Ca
    You need to replace the bad capacitor on that combination meter - that's why it'll boot-up every once in a while. It'll be fairly obvious, once you get that board out. They usually bleed or get bloated.
    Hope this helps...
  4. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    See repair of the instrument panel Gen2
    [/QUOTE]
