No "dinger" when I leave the headlight on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fireboy, May 2, 2015.
  1. Fireboy
    Fireboy New Member
    29
    South Carolina
    I sometimes manually cut the headlights on during the day and I noticed that there is no bell or dinger that alerts me that they're on when the car is cut off. I assume the lights will cut themselves off after a period of time? Just concerned I might kill the battery if I don't notice I left them on.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, no warning chime, because they will automatically turn off.
    I still turn off the headlights manually because I don't leave it to chance that the will. I don't want to end up with a dead battery if the lights stay on.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    I believe there is a vehicle setting that lets you adjust the amount of delay, including none (they go off immediately). It seems like I saw it when I as looking for the DRL setting.
  4. matt b.
    matt b. Member
    251
    60
    L.A.
    mine goes off automatically after 30 seconds
  5. fuzzy1
    10,167
    The auto-off delay can be configured to 0, 30, 60, or 90 seconds.
    But do beware that it is possible to defeat the auto-off feature, such as by exiting through the passenger side door, or by turning the lights off then back on after shutting down the ignition. Therefore, after shutting down, if you touch the light switch at all, then you must leave if OFF.
    xliderider likes this.
  6. Mendel Leisk
    38,717
    If I leave the headlight on "AUTO" setting, yeah: they'll turn off automatically. But as far as I know, if I have them set to regular headlights on position, or parking lights only, the car gives NO warning. Just happily burns down the battery.
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    The Prius three doesn't have Auto setting on the stalk, no warning chime, lights (Parking/Lowbeams) go off after timeout.
    The Camry has Auto setting, lights also turn off after timeout. Don't know about parking lights, haven't tried those.
  8. Mendel Leisk
    38,717
    Mine looks like the pic. To tell you the truth: I haven't got the guts to test what I said about the headlights not going out, maybe some braver soul can? :oops:
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Actually, the Camry's stalk goes Off>Auto>Parking>Lowbeam, yours has the Auto position at the end.
  10. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I don't have the auto headlights on my 2010 Prius 11. I have left them on to see what happens and they always turn off after 30 sec.
  11. fuzzy1
    10,167
    This may be a difference between Canadian and U.S. market models.
    My manual pictures several varieties of turn stalk markings, with and without AUTO (as in auto-on, not the simpler auto-off), none of which exactly match my equipment.
  12. Fireboy
    Fireboy New Member
    29
    South Carolina
    Thanks guys for your responses
  13. bisco
    49,469
    pleasure.
  14. fuzzy1
    10,167
    A two minute test will produce a definitive answer without putting the battery at any risk.
  15. Former Member 68813
    3,524
    981
    US
    i adjusted to 0. while i manually turn them off, my wife does not. i see no purpose of that 30 seconds stressing this tiny 12V battery.
  16. xliderider
    7,869
    3,116
    Honolulu, HI
    The delay is so one can get to the front door, etc with illumination from the headlights. In other words, a safety/convenience feature. ;)
    lar.smith42 likes this.
