No driveline. What is that center hump for?
Discussion in 'Gen 2 Prius Main Forum' started by V8Cobrakid, Apr 6, 2005.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    This has been bugging me for a while. There is the center hump in the prius. It seems to be squared off too. The car does not have a driveline. All cables run under the car. What is in that center hump? It's not a camel.. there is no water.. if so.. let's drain it.. i want better mpg :) so. anyone know if that thing is hollow? If so, i want to pass things through it. :)
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    The exhaust system runs thru there. Without the hump,where would you put it, :roll:
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Acrtually, doesn't the 2 HV lines and the main 12V line run through a tunnel about there?
  4. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I guess I better get under there and check out how close those HV lines are. I'm planning on mounting my XM SKYFY2 on the center hump. Wouldn't want a little sheet metal screw hitting any of those power lines.
  5. DanMan32
    3,799
    27
    Tampa Bay, FL
    Looks like the frame wire runs on the driver side under the car, not at the center.
  6. V8Cobrakid
    3,790
    152
    yeah.. you can see the orange cables under the car passing through a clear plastic casing towards the driver side. Exhaust? last time i saw, i didn't think it ran that high.... *scratches head* i'll crawl under my car again and look.
    Either way, there is still leftover room in that thing. Even if the exhaust does run in the general area.
    I'll look.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Could be structural too.
    Take a flat piece of sheet metal - it's flimsy. Use a press or a forming tool to put a crease or two in it, and it becomes much more rigid.
  8. V8Cobrakid
    3,790
    152
    i remember hearing it was cosmetic a long time ago. This is why i'm asking. Give this post a few days. It takes people a while to find it. Not everyone is logged on everyday like me. Priuschat is like an I.V. line for me :) it pumps the green into me :)
    But.. like i said.. i heard it was cosmetic. The car simply looked too weird without it.
  9. rick57
    rick57 Member
    572
    Circleville, Ohio
    The exhaust is situated in there just like other Toyota's. If you raise it up higher, I wouldn't think you would not get that much air flow around it. And putting it higher into the tunnel would put it closer to the floor pan and you know what is on the other side, the interior and carpet. Wouldn't want to fry your carpet, now would you, :lol:
  10. Tideland Prius
    16,445
    Also, if the exhaust is there, then it would allow a flatter underbody. Most of the car underneath is flat with carboard umm.. sheeting to smoothen out air flow so anything that can be tucked away will be tucked away.
  11. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    The exhaust (and converter) are in the hump, allowing the rest of the body to remain flat for better aerodyamics while maintaining the 4.9" ground clearance. Also, from a point below the console, the parking brake cable is transfered via a lever assembly from the interior of the car (on top of the hump) to the exterior and two cables run from this point to the rear brakes. The hump thus allows the lever for the parking brake to be protected from road debris.
  12. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    I always thought the purpose of the hump was to act as a sibling demarcation line. :wink:
    “Daddy, Patrick is kicking me again!â€
    "Who ME!" :roll:
  13. rick57
    rick57 Member
    572
    Circleville, Ohio
    And the console keeps your better (?) half on her/his side? :roll:
    "Don't tell me how to drive!"
  14. bobc
    bobc New Member
    361
    Durham, NH
    I thought having the hump made the bottom of the car look and act like the bottom of a ski to keep the car tracking straight.... :)
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Rick:
    So, have the cats been keeping you company when you sleep on the couch?
    Jay
  16. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    1. Exhaust system
    2. Wiring from battery in trunk to motor up front
    3. Adds structural rigidity to floor plan
    4. Gives center passenger in rear seat an excuse to complain.
  17. V8Cobrakid
    3,790
    152
    2. wiring.... wiring still runs on the drivers side :) you can see it when you are under the car. :)
    4.Gives... hey.. at least it's flat. Anyone ever sit middle and have that hump be round? is there any good place to put your feet? no.. they slide off. lol
  18. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(jayman\";p=\"79139)</div>
    Rick:
    Jay[/b][/quote]
    No, Jay. they have not, :lol: They wouldn't sleep with me anyway.And she doesn't know what I write about on here, ha!
    Do I have " Stupid " wrote on my forehead? Maybe I better check in the mirror, :roll:
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Rick:
    Well you better be careful that she doesn't figure out how to hack into your notebook and see what you write. Or you'll be in deep s***.
    That's why it's essential to have at least one comfy couch in the house, it makes that "involuntary" separation easier to deal with.
    Jay
