No EV when first powered on but plenty of battery power?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Nov 24, 2014.
  1. qdllc
    qdllc Senior Member
    1,371
    399
    This has happened a few times since I've gotten the recall done, but it's not until now I'm getting miffed.
    If I start the Prius first thing in the morning and try to use EV mode, the system says it's not available. Battery indicator is over 50%...more than enough to say it's not a lack of available power cutting off access to EV mode.
    Problem does not reproduce once the car's been driven for a while.
    This is a pain because the chief advantage of EV mode is the ability to move the Prius without bothering with the ICE.
    Are there other factors that cut off access to EV mode I don't know of? Air/engine temp...for example?
    Other issues I'm having, but I think should be easy to correct, is that I got a rough "stumble" when the ICE kicked in this morning. Only thing that stands out is that I hand-washed the car on Saturday, but I don't see how that should affect anything. I'm adding a can of B-12 Chemtool to the tank and filling up this morning in case it's just a fuel system issue.
    51,155
    engine temp might play into it. did you used to be able to enter ev with a cold engine in winter?
    on the rough startup, it's from unburned fuel in the intake manifold, and is caused by moving the car in the driveway, and shutting the engine off before warm up is complete. because ev wasn't available for the short move. it's very aggravating.
  3. qdllc
    qdllc Senior Member
    1,371
    399
    I don't recall last winter. I hardly ever use EV mode. I just happen to notice it now, but it seems odd to compel you to use the ICE when all you want to do is move the car in the driveway.
    Keep in mind that my Prius is garage-kept, so it's not as cold as if it was parked outside overnight.
  4. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    It seems there is an EV lockout when ICE temp is below 68deg.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Your car is acting exactly the way my '13 C does......making the EV button mostly worthless.
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Since it's cooler out now, I've run into the same problem and it is irritating. However, I'm sure there's some reason that they don't make EV mode available, though I can't think of what it might be.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Is this a new thing? Or a US model thing? It's always below 20c here. I can use EV mode any time (other than well below freezing) so long as I press it in the first 5 seconds or so.
    If it is a new thing it's a bad idea. EV mode is ideal for moving the car about on your drive or out of the garage.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I'll have to experiment a little with the button, but it seems like I was always able to just press it anytime before the ICE started. Maybe I've been pressing it before all the electronics are up and running or something.
  9. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I think it's a US model thing, present at least on all the Gen III models. EV mode is not allowed when first starting the car unless the engine coolant temperature is above 68°F/20°C. If you're moving the car into the driveway to wash it, the only thing you can do is floor it and get it in place in the 12 seconds before the ICE kicks in. ;) (Just don't run over your kids while doing this...)
    It's not the only way they gimped our EV mode; IIRC, you guys can go faster than 25 mph too.
    GrumpyCabbie likes this.
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Yes and no. We can drive upto 31 mph in EV mode but that is just the displayed speed. 31 mph displayed comes out as about 26/27 mph actual.
  11. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    An engine heater keeping temp at 69 deg is one solution, though maybe not a good one.
  12. qdllc
    qdllc Senior Member
    1,371
    399
    Got the message again this morning. Reading it quickly, it said the motor was warming up.
    This, to me, is a severe design oversight. Yes, battery potency drops when it's cold, but it should be below 45F before EV is locked out.
    I wonder if Toyota can fix this with a "patch?"
    Anyone know who to contact at Toyota who could answer this question?
  13. Mendel Leisk
    40,586
    ^ You've actually got something like 15 seconds of EV after start up, regardless of EV status, ambient temp, state of charge. If you're very quick, you can use it to get the car from garage to driveway. If you shut down and restart, you get another 15 seconds.
    I would LOVE a patch, Toyota, to increase this 15 seconds to, say, 60 seconds. And if it's not asking too much, display a countdown on the dash, so you know when you're reaching the limit.
  14. qdllc
    qdllc Senior Member
    1,371
    399
    Yeah, but 15 seconds is hardly time for the garage door opener to do its job.
  15. Easy Rider 2
    1,584
    258
    Ocala, FL
    Plan A H E A D !! :)
    I would love to have 15 seconds; my C is more like 4 seconds.
  16. Mendel Leisk
    40,586
    Umm, open the garage door first? I didn't say I was happy with it, lol. It is what it is, as St Vincent would say.
    And yeah, 60 seconds would be nice, Toyota.
  17. qdllc
    qdllc Senior Member
    1,371
    399
    Or a "press EV and START at the same time" for an added delay.
  18. bisco
    51,155
    pm the priusteam, they are pretty good at sorting things like this out. doug, or erica.
  19. qdllc
    qdllc Senior Member
    1,371
    399
    How do I find a list of the people on the team? The first names bring up multiple matches in search.
  20. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    There is a user actually called "Prius Team".
