No heat ... blend door?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Natomas, Dec 13, 2019.
  1. Natomas
    Natomas Junior Member
    Sacramento
    2013 Prius v wagon
    Hello -
    I'm new to the Prius world. I picked up a 2013 wagon last month (157k), very clean, but it was unseasonably warm that week. Soon find out there's no heat. All the controls work except it blasts cool air.
    I took it to a shop for a diagnosis. There's nothing wrong according to any of the computers. The coolant is a little "dirty" but the mechanic doesn't think that's the problem because it seems to be flowing. It's hot going into the core, and hot coming out. So, by process of elimination, the mechanic thinks the problem is likely to be the blend door actuator.
    Based on his explanation and what I could understand on the Internet (I don't have a mechanical background), it would make sense. BUT it's a $1000 job because he has to lift the dashboard. And he doesn't know for sure that's the problem.
    Any other ideas of what this could be? I would really hate to drop $1000 and find out it's going to be, oh, you have to replace the whole HVAC system.
    Thanks in advance for your advice. I bought the Prius because it seems to have a reputation for low maintenance costs compared to other high mileage cars, and I thought I had a sense of the things I'd be taking a chance on (the battery, the head gasket), but heating wasn't on my radar...
  2. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    Is your mechanic knowledgeble on Prius? Is the blower motor running? Can you feel it blowing cool air like the blower motor is operating? I would be inclined to take it to a dealer for a second opinion before I would spend $1000 on this repair.
    FYI: My daughter took her Accord to an independent mechanic when it wouldn't start. He told her it was the starter and would cost $700 because he had to remove suspension parts on one side to get at the starter.
    I advised her to take it to the local Honda dealer just to verify that the starter was the problem. The dealer concurred that it was the starter but their price was $380. When she repeated the conversation with the independent mechanic and his price, the service manager said you probably would have to take suspension parts off to get access if you didn't have the correct tools to do the job.
  3. Natomas
    Sacramento
    2013 Prius v wagon
    Update, for posterity:
    I took it to a second mechanic (both are well rated hybrid specialists - I wasn't able to get in to see dealer) who was able to see the blend door was operational. However he noticed the coolant was the wrong color. He flushed and saw white gunk come out. Apparently someone used some kind of head gasket sealant shortly before I bought the car. I had to replace the leaking head gasket plus the radiator, which was fouled up from the sealant. The mechanic hosed a special cleaner through the system to clean out the core (fingers crossed).
    A week later the heat goes out again and I get a high temp warning on the highway. Coolant reservoir is super low. Take it back - the engine water pump is dead.
    Total is $3700, more than half what I paid. Talk about a money pit. Of course if I had wanted to spend over 10 grand I would have gotten a lower mileage car!
    Mechanic says the sealant should only affect the head gasket, the radiator, and water pump, and the core, so I should be in the clear from this God forsaken mess. Does that sound right?
    49,504
    i hope so, all the best! we have been seeing a lot of these shenanigans lately, due to gen 3 egr weakness
  5. ChapmanF
    15,660
    and the EGR cooler, and the isn't-there-another-exhaust-to-coolant-heat-exchanger-lower-in-the-exhaust, and ...
    With luck, the flushing stuff will have cleaned out most....
  6. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    According to the email I got from Blue Devil, and my own experiences, if you flush the system with a 50/50 mix of white vinegar and water, then rinse the system with water, it should take care of the stop leak.
    I used the Blue Devil myself when I got mine due to a leaking head gasket. Then in July of 2018, the engine failed. Fast forward to a few weeks ago, the ICE was running when maybe it shouldn’t have been. I found the thermostat clogged in a half open position with the stop leak. That’s what prompted the email to Blue Devil.
