No Heat Going to the Feet
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Jan 30, 2015.
  1. Siward
    Siward Active Member
    296
    124
    Toronto
    Hi PriusChat,
    This is the first winter with my 2012 Prius, and I've been suspicous of the climate controls. Today, my passenger complained that there was not heat going the to feet. I've always worn insulated shoes/pants so I didn't really notice before.
    I jacked up my fan, increased the temperature and changed the aim to the feet/knees only. I then put my hand to where the gas pedal is. I couldn't feel any air flow at the feet. There was still plenty of air coming out of the upper side vents that blows towards your chest. The upper vent got hot, but not the feet.
    Does anyone know why there's no/little airflow to the feet? I'm thinking of checking my carbin filter but it is too cold be pulling out parts. I'm now suspicious if my car's air direction function works properly.
  2. working1
    working1 Active Member
    121
    111
    I notice the same issue even with the air direction setting for bottom flow only. Not sure if any other settings make a difference, but, my feet do get cold if I'm not wearing heavy shoes or boots.
  3. JC91006
    16,482
    8,398
    Servo motor bad? Or needs lube
    49,458
    yup, the flow should switch about 90%. if you have the fan on low and the ice is off, you can hear the damper move when you switch it.
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    I switched to the foot-only blower option this morning. The feet were toasty warm in no time. The air blowing out was hot & abundant. Only a trickle came out of the other vents.
    Something is wrong if yours doesn't do the same.
  6. Siward
    296
    124
    Toronto
    What temperature do you guys set heater at? I tried setting it to high, and it wasn't any hotter than it was at 24 degrees.
  7. bisco
    49,458
    how long was the engine on for? i usually find 75f to be a good place to start, then keep ticking it down after i'm warm. i usually feel comfortable around 67-68 depending on the outside temp.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'm going to have to experiment a little with this.
    I've never got very good air flow to the foot well. But I assumed it was just normal.
    Now I'm wondering if I should be expecting more?
    I think there is "some change" but it's nowhere near the airflow going to 90% to the foot well area.
