No heat (knocking, popping) need to bleed coolant?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by GrimChaos, Mar 19, 2020.
  1. GrimChaos
    GrimChaos New Member
    Chicago
    When I turn on my Prius v 2012. There is knocking and popping. The system turns on auto for a minute (can't turn off) and then after that I can change the temp/fan speed (but no heat).
    If I raise up my coolant reservoir I can get heat.
    Does this mean the coolant needs to be bleed?
    If yes, how do you do it on a Prius v 2012?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,724
    Texas Hill Country
    Try this video
    49,504
    if you haven't changed the coolant, and this started happening out of nowhere, i think you have bigger problems
  4. Mendel Leisk
    38,732
    How many miles on it?
  5. GrimChaos
    Chicago
    59,000
